Does the CAN mapping apply to i3 LIM module as well when using a ZombieVerter and a Leaf PDM? Problem seems that the I3 LIM can't be configured to map can messages, like Foccci can. But is it possible that Zombieverter sends the commands needed (which ones)?
Goal is to have CCS instead of Chademo for DC and Type1 for AC. The Chademo should be "converted" to be the DC / CCS charger so the Chademo HV contactors (inside Leaf PDM) are used and no additional / external contactors are needed. And AC should be handled via Leaf PDM as usual.
As far as I understand the CP and PP of the CCS socket need to be connected to I3 LIM to make DC charging work. As the PDM usually also needs those pins I need to emulate those or switch them between the two devices (which seems not that elegant to me).
As the PDM receives it's messages via CAN: can it be fooled to use the CP/PP signal from i3 LIM? Accoriding to the i3 LIM wiki page the CAN message sent by LIM is at 0x3B4 and contains CP, PP and inlet voltage right?
Or are those values available via CAN and can be mapped to the PDM so AC and DC charging is possible alike?
so in short:
1. when using a Leaf PDM are external contactors needed for DC charging or can the internal Chademo ones be used?
2. how to handle the CP/PP signals so both types can use their state without manual switching via relay?
