Leaf PTC Cabin Air Heater
cnstrct
Has thanked: 11 times
Post by cnstrct »
Is anyone using the leaf PTC cabin air heater? I have found info for the coolant heater but have been searching high and low for details to control the air heater with no luck. This one is out of a 2019 part number 27143-3NK1B
Been thanked: 412 times
Re: Leaf PTC Cabin Air Heater
cnstrct wrote: Mon Dec 29, 2025 11:30 pm Is anyone using the leaf PTC cabin air heater? I have found info for the coolant heater but have been searching high and low for details to control the air heater with no luck. This one is out of a 2019 part number 27143-3NK1B
Could be this link? He is also refering to LIN protocol for "dry" heater...
https://ev-olution.yolasite.com/nissan- ... roller.php
Some more info in video...
cnstrct
Post by cnstrct »
Thanks arber333, looks like you're right, they do refer to a dry heater with separate ino file, thanks!
UPDATE. I am also sharing controller code for "dry" PTC heater (from LEAF made after 2013). It was tested and reported as fully working. Please only use it if you using PTC in custom project and not in LEAF vehicle. As LEAF made after 2013 has two other slave modules connected to LIN bus.
https://ev-olution.yolasite.com/resourc ... r_V1.1.rar
Dddrewski
Post by Dddrewski »
Hello. I am new to this forum and seem to have hit a wall implementing control for the Leaf PTC Cabin Heater. Were you able to get this working? I get similar LIN bus messages from the heater and it doesn't heat up.
cnstrct
Post by cnstrct »
Sorry @Dddrewshki I haven't had a chance to try it yet.
