Project validation BMW E30 + Tesla SDU
ElectricBMW
Post by ElectricBMW »
my name is Thomas...
and i have an empty shell of a BMW E30 and it would be a waste to throw away.
I thought about convertig it some years ago but it was way out of budget.
Times and prices have changed and i want to build it in the near future.
Getting the needed parts and building it is one thing.
Matching the electronics and software is a totaly different thing.
I am no programmer! And this will be my challenge in this project.
Aaaand the german TÜV.
So, my plan:
-Tesla rear SDU on the rear axle of the car with OI board.
(this should be the easy part)
-8-12 HV batterie modules in fitting locations with OI Flying ADC BMS.
First question: :?: Can the OI BMS work with more than 8 modules? Or is 128 cells my max?
If so: :?: is it wise to split battery modules to fill the BMS?
German TÜV:
TÜV Merkblatt 764 is my guide.
Apart from building a TÜV worthy car, there is safety.
I checked HV safety and Throttle safety so far.
One thing on my list is "Ready to Drive"-state and switching "Forward", "Neutral", "Rewerse".
:?: -If i open a door it should switch to "Not Ready/Neutral", right?
:?: -Switchig "Forward" or "Rewerse" should only be possible with Brake switch + Standstill?
I don´t want to hit Rewerse while going Forward and ruin a beautiful day.
This is it for my Newbe-Introduction.
I know there are many more checkmarks to set but above all is the TÜV-guy giving the "GO!"
And me, confident to start.
Thomas...
wishing a nice weekend :)
"When is the best time to plant a tree?
20 Years ago!
When is the second best time to plant a tree?
Today!"
Been thanked: 1135 times
Re: Project validation BMW E30 + Tesla SDU
If it were me I'd use an M3 drive unit. Much better inverter but i am biased :)
ElectricBMW
I guess those are over my budget.
SDU + OI Bord+ OI BMS goes for under 2k.
Suitable batteries well under 10k.
20 Years ago!
Today!"
128 cells is way over SDU voltage. What's the plan there?
Yes direction switching is only possible below a settable speed
ElectricBMW
Hi Johannes,
nothing fancy. It will be a ~350V System. Maybe ~390V.
In one of your videos you said 8 BMS Modules is the max to chain together.
I don´t know what HV Battery i buy in the future. Some have 8 some have 12 Modules.
I´d like to have one BMS Module for each Battery Module. Just to have it clean.
But if you say it is overrated and 6 BMS Modules for 96 Cells in whatever configuration is good, i´ll do that. (i´d buy 8 anyway)
20 Years ago!
Today!"
ElectricBMW
Figuring out Battery Options :idea:
I think a 12 Modul-setup would be the way to go in terms of fitment.
I can fit 8 in the enginebay and 4 in the fueltank location.
4 BMS in the front and 2 in the back.
VAG battery modules (ID4 or e-Tron) would be 300kg.
200kg in front
100kg in back + 90kg Motor
Front weight cancels out nicely and rear needs some work.
Overall nice ballance and ~82kwh.
20 Years ago!
Today!"
