Outlander rear inverter DC connections
FFMan
Has thanked: 9 times
Been thanked: 50 times
Post by FFMan »
I should know the answer to this as i've been here before but my notes don't record this...
Which of the DC in connections on the Outlander rear inverter is the positive ? I think its the left hand one (i.e. next to the motor wires) in this picture as this has the 30a and 40a fuses on the two small outputs but naturally it would be good to have this confirmed.
thanks
Been thanked: 413 times
Re: Outlander rear inverter DC connections
FFMan wrote: Thu Apr 23, 2026 4:36 am I should know the answer to this as i've been here before but my notes don't record this...
POSITIVE is the rail where fuses come out of. NEGATIVE side is not fused.
