DC Fastcharging via CCS2 for Renault Twizy BMS
MPS
Post by MPS »
Hi everybody and thanks for this awesome open source & hardware project!
Do I understand correctly, that CCS2 allows to drive fast charging (with those external charging stations) for essentially any LiFePo4 battery packs, as long as one has an CCS2 port and the FOCCCI board continuously relays the cell measurements from the BMS through the communication line to the charging station? For example, if one manages to grab the cell measurements from a Renault Twizy BMS then one could fast charge its 6kWh LFP battery with DC from the charging station? Shouldn't this reduce charging time quite a bit, say very roughly ~12 min at 30kW?
muehlpower
Been thanked: 186 times
Re: DC Fastcharging via CCS2 for Renault Twizy BMS
Post by muehlpower »
In principle, yes. Provided the battery and cooling system can handle it. With the Twizzy, the main obstacle will be the 48V system, since DC charging stations typically start at 150V to 200V.
MPS
Post by MPS »
Thanks!! Indeed, onboard battery seems between 40-60V depending on charge -- very sad :(((
Seems CHAdeMO instead of CCS2 won't help there either?
Found this EV schema: https://www.twizy-forum.de/attachment/41852
Seems easier then to build a separate range extender high voltage battery with BMS, FOCCCI, and CCS2 port to get DC fast charging from the stations.
The range extender then needs separate DC-DC converter to hook into the EVs battery recuperation, or is there something easier that I'm missing?
Guess any cheap >200V battery system, with high kWh, C-rating, and accessible BMS, would be a good basis for this endeavor, though I was hoping for fast charging with little extra stuff.
DVD3500
Has thanked: 88 times
Been thanked: 9 times
Post by DVD3500 »
I have a similar problem with my conversion I am planning.
It is likely a ca 100 volt system but when I see the number of CCS chargers on the routes I want to drive with the car I would like to have the option: Not because I want the speed of charging but just to have the freedom of choice.
I could do a 22 KW AC system fairly easily but I did a trip to Buxtehude a few weeks back and a lot of the AC chargers there only put out 4-9 KW for my Enyaq which strengthened my desire for some sort of a fast charge option...
I saw a video about how the Rivian truck actually changes the batteries from parallel to serial to up the voltage for fast charging and then switches back to increase capacity.
I would have fairly easy access to the batteries so I was wondering about the feasibility of doing that as well...
One other reason is I would like to take part in the e4 festival on the Hockenheimring and the standard chargers you have use are CCS :;-) :-)
P.S.Mangelsdorf
Has thanked: 323 times
Been thanked: 351 times
Post by P.S.Mangelsdorf »
DVD3500 wrote: Mon Apr 27, 2026 9:39 am I saw a video about how the Rivian truck actually changes the batteries from parallel to serial to up the voltage for fast charging and then switches back to increase capacity.
That's actually the GM EV trucks (Silverado, Hummer, Sierra, and Escalade), not Rivian. They are able to do so because they are essentially using two 400V packs stacked on top of each other. So they run in parallel while driving, and series when charging on an 800V capable station.
DVD3500
Post by DVD3500 »
Oh right, I got that confused with the Cannonball run Rivian... :-( I am getting old ...
P.S.Mangelsdorf
DVD3500 wrote: Tue Apr 28, 2026 12:45 pm Oh right, I got that confused with the Cannonball run Rivian... :-( I am getting old ...
In fairness to you, there were videos about both, on the same channel, released fairly close to each other.
Been thanked: 1913 times
Mathieu Rech did the same on his Landcruiser conversion. It is also a 120V system and he used a funky relay matrix to switch between 2 parallel 120V pack and series 120V packs. Worked a treat.
uhi22
Has thanked: 245 times
Been thanked: 684 times
Post by uhi22 »
A list of different charger types, with their minimum supported voltage, is available in the wiki: https://openinverter.org/wiki/CCS_Fast_ ... (Overview)
The most critical is the Tesla Supercharger, which rejected requests below 230V.
