Page 2 of 2
Re: Lexus GS450H Powered BMW E60
Posted: Mon Nov 04, 2024 3:33 pm
joeflickers wrote: Mon Nov 04, 2024 2:50 pm how did you decode this as ive got a similar selector and getting the wake up message
https://github.com/Tom-evnut/BMW-F-Series-Shifter
https://github.com/damienmaguire/Stm32- ... _Lever.cpp
Re: Lexus GS450H Powered BMW E60 (WIP)
Posted: Mon Nov 04, 2024 7:24 pm
by 7yatna
I Did install e60 facelift shifter and worked it in the zombie code.
I Dont use the wake up message i use the wakeup line and connected to the wakeup line to the power train like a normal e60.
There are other shifters that had been worked by tom and damien form other cars. i got e60 shifter coded if you are using this one i can send you the code for it.
e60 shifter isn't in the current zombie release.
Posted: Tue Nov 05, 2024 8:35 am
by joeflickers
7yatna wrote: Mon Nov 04, 2024 7:24 pm I Did install e60 facelift shifter and worked it in the zombie code.
That would be very helpful, you can share the code. I bought the E60 lever thinking it's the correct on from the UK as we don't have as many spare parts for the F30 here in Kenya
Posted: Tue Nov 05, 2024 11:39 pm
by joeflickers
joeflickers wrote: Tue Nov 05, 2024 8:35 am That would be very helpful, you can share the code. I bought the E60 lever thinking it's the correct on from the UK as we don't have as many spare parts for the F30 here
Posted: Thu Nov 07, 2024 9:18 am
by 7yatna
here is the code translating the shifter from my zombie code.
there are other stuff incorporated for other things but i believe all what you need is here.
 case 0x198:
	  uint32_t GLeaver = data[0] & 0xFFFFFF00;   //unsigned int to contain result of message 0x198. Gear selector lever position
	  switch (GLeaver)
            case 0xC5CF0000:  //park button pressed
               this->gear = PARK;
               gear_BA = 0x03;
               shiftPos = 0xe1;
			   MPos = 0x0f;
			   SPos = 0xf0;
			   Sport = 0;
               break;
			case 0xC5CD2000: //R+ Park position
			   Param::SetInt(Param::Gear, 0);
			   this->gear = REVERSE;
               gear_BA = 0x02;
               shiftPos = 0xd2;
               MPos = 0x0f;
			   SPos = 0xf0;
			   Sport = 0;
			   break;
            case 0xC0CD2000: //R+ position
               gear_BA = 0x02;
               shiftPos = 0xd2;
               MPos = 0x0f;
			   SPos = 0xf0;
			   Sport = 0;
			   break;
			case 0xC0CC3000: //R to Neutral
               this->gear = PARK;
               gear_BA = 0x01;
               shiftPos = 0xb4;
               MPos = 0x0f;
			   SPos = 0xf0;
			   Sport = 0;
			   break;
			case 0xC0CF0000:  //not pressed
				Param::SetInt(Param::Gear, 2);
				Param::SetFloat(Param::throtramp, ThrotRamp);
				if ((Param::GetInt(Param::dir)) == -1)
				MPos = 0x0f;
				SPos = 0xf0;
				Sport = 0;
				break;
			case 0xC0CE1000: //D to Neutral
               this->gear = PARK;
               gear_BA = 0x01;
               shiftPos = 0xb4;
               MPos = 0x0f;
			   SPos = 0xf0;
			   Sport = 0;
			   break;
            case 0xC0CB4000:  //D+ pressed
			   this->gear = DRIVE;
               gear_BA = 0x08;
               shiftPos = 0x78;
               MPos = 0x0f;
			   SPos = 0xf0;
			   Sport = 0;
			   break;
			case 0xC5CB4000:  //D+ Park pressed
			   this->gear = DRIVE;
               gear_BA = 0x08;
               shiftPos = 0x78;
               MPos = 0x0f;
			   SPos = 0xf0;
			   Sport = 0;
			   break;
			case 0xC0CA5000:  //Sport Minus
			   Param::SetInt(Param::throtramp, 12);
			   this->gear = DRIVE;
			   gear_BA = 0x05;
               shiftPos = 0x78;
			   MPos = 0x5f;
			   SPos = 0xf2;
			   break;
			case 0xC0C96000:  //Sport Plus
			   Param::SetInt(Param::Gear, 1);
			   this->gear = DRIVE;
			   gear_BA = 0x06;
               shiftPos = 0x78;
			   MPos = 0x6f;
			   SPos = 0xf2;
			   break;
			case 0xC0C87000:  //  S-M-D button pressed
			   switch(Sport)
				   case 0:
					   this->gear = DRIVE;
					   gear_BA = 0x08;
					   shiftPos = 0x78;
					   MPos = 0x0f;
					   SPos = 0xf1;
					   Sport = 1;
					   break;
				   case 1:
					   break;
               break;
		break;
Posted: Thu Nov 07, 2024 11:24 am
7yatna wrote: Thu Nov 07, 2024 9:18 am here is the code translating the shifter from my zombie code.
Please do not dump code in a random place on the forum. Create a thread so it can be found and properly integrated into the zombie code base.
This clearly is not the full file to be a direct drop in for a gear lever in the Gear Lever class.
Posted: Thu Nov 07, 2024 6:10 pm
by 7yatna
tom91 wrote: Thu Nov 07, 2024 11:24 am Please do not dump code in a random place on the forum. Create a thread so it can be found and properly integrated into the zombie code base.
Your comment contradicting itself Tom.
I Know that it isn't a code to be placed in zombie code base, and this is a snip of a function that can not be compiled as is nor can be used at all unless someone knows what he is looking at can use it.
so it isn't a code. that's why i "Dumped" It.
the reason behind we don't have floating code "Dumped" around is to prevent hexes from flying and un-expected "THINGS" as you said earlier.
No one care enough about e60 development code i did over the past year so better keep that dangerous stuff off zombie code base.
this doesn't meant if someone asks for a something i wouldn't help, The rule is i don't give hexes nor binaries, not a complete ready to compile code.
hopefully you are taking my comments gracefully and I'm trying to take yours as not internationally busting my bones.
Posted: Thu Nov 07, 2024 7:07 pm
7yatna wrote: Thu Nov 07, 2024 6:10 pm Your comment contradicting itself Tom.
Code is anything, with code in it.
I am telling you to create a post so its clear to track this, then this code you have worked on can be implemented in the Zombie base code.
This way people can be pointed to it is being worked on and feedback from users, like yourself, who have on their own already worked it out.
Having it in the middle of a "random"/not easy to locate thread makes zero sense from a trackability point of view.
Posted: Fri Nov 08, 2024 12:13 am
by 7yatna
Thanks Tom.
Point Noted.
Posted: Fri Nov 08, 2024 5:19 am
by joeflickers
 case 0x198:
	  switch (GLeaver)
               this->gear = PARK;
               gear_BA = 0x03;
               shiftPos = 0xe1;
			   MPos = 0x0f;
			   SPos = 0xf0;
			   Sport = 0;
               break;
               gear_BA = 0x02;
               shiftPos = 0xd2;
               MPos = 0x0f;
			   SPos = 0xf0;
			   Sport = 0;
			   break;
               gear_BA = 0x02;
               shiftPos = 0xd2;
               MPos = 0x0f;
			   SPos = 0xf0;
			   Sport = 0;
			   break;
               this->gear = PARK;
               gear_BA = 0x01;
               shiftPos = 0xb4;
               MPos = 0x0f;
			   SPos = 0xf0;
			   Sport = 0;
			   break;
				MPos = 0x0f;
				SPos = 0xf0;
				Sport = 0;
				break;
               this->gear = PARK;
               gear_BA = 0x01;
               shiftPos = 0xb4;
               MPos = 0x0f;
			   SPos = 0xf0;
			   Sport = 0;
			   break;
			   this->gear = DRIVE;
               gear_BA = 0x08;
               shiftPos = 0x78;
               MPos = 0x0f;
			   SPos = 0xf0;
			   Sport = 0;
			   break;
			   this->gear = DRIVE;
               gear_BA = 0x08;
               shiftPos = 0x78;
               MPos = 0x0f;
			   SPos = 0xf0;
			   Sport = 0;
			   break;
			   this->gear = DRIVE;
			   gear_BA = 0x05;
               shiftPos = 0x78;
			   MPos = 0x5f;
			   SPos = 0xf2;
			   break;
			   this->gear = DRIVE;
			   gear_BA = 0x06;
               shiftPos = 0x78;
			   MPos = 0x6f;
			   SPos = 0xf2;
			   break;
			   switch(Sport)
				   case 0:
					   this->gear = DRIVE;
					   gear_BA = 0x08;
					   shiftPos = 0x78;
					   MPos = 0x0f;
					   SPos = 0xf1;
					   Sport = 1;
					   break;
				   case 1:
					   break;
               break;
		break;
superb, can see you have impremented different driving modes
Posted: Fri Nov 08, 2024 8:38 am
by 7yatna
joeflickers wrote: Fri Nov 08, 2024 5:19 ammodes
I have the car running and doing way so much stuff for over a year now. sport mode, manual mode, i introduced Auto shifting to the GS450H Zombie code before Tom and Damien do it differently.
as far as i know im the first and only to blend gears in GS450h, this required HW mode on zombieverter.
happy to help
Posted: Fri Nov 08, 2024 9:33 am
by Jacobsmess
I might have a custom aluminium coupler for the GS450H to a BMW E46 prop if this is of use to you? I'll need to double check first as it might already be spoken for however.
Posted: Mon Nov 11, 2024 12:01 pm
by joeflickers
7yatna wrote: Fri Nov 08, 2024 8:38 am I have the car running and doing way so much stuff for over a year now. sport mode, manual mode, i introduced Auto shifting to the GS450H Zombie code before Tom and Damien do it differently.
happy to help
Excellent... Are you able to share more.. Like your code.. Idd be happy to replicate what you have.. Or bin file.. I'm not soo good in coding but in hardware and IoT development.. I have the gs450h in a W124 200E and happy so far having done 16k-kilometers.. I'm not happy with stock gear selector and wanted something modern.. I was not able to implement the code snippet you shared for my gear selector..
I'm also interested to know if perhaps you have a visual screen to view zombie parameter like speed, inverter temp apart from using the spot values as I have to always open web-browser's on my android radio..
I'm using Orion bms2 and have developed an oled showing most parameters.. My battery is 77kw from Hyundai and I get a decent 420km.
Posted: Mon Nov 11, 2024 12:45 pm
by marcexec
joeflickers wrote: Mon Nov 11, 2024 12:01 pm Excellent... Are you able to share more.. Like your code.. Idd be happy to replicate what you have.. Or bin file.. I'm not soo good in coding but in hardware and IoT development.. I have the gs450h in a W124 200E and happy so far having done 16k-kilometers.. I'm not happy with stock gear selector and wanted something modern.. I was not able to implement the code snippet you shared for my gear selector..
I'd love to see a build thread or even just pictures. My dad has multiple S/W124 and I have a W201 myself. Extremely solid cars.
Posted: Tue Nov 12, 2024 6:04 am
by 7yatna
back to my previous comment.
Unfortunately due to how critical and dangerous flying code/bins without traceability like Tom and others pointed i can not and will nor share complete bins nor even full code.
after all your life is at the line here. me and others had close call due to some minor variable was not tuned in correctly.
i can help and give pointers towards a specific debug or an improvement. each project has a character and life of its own. i might be able to share the common parameters but remember my code is very custom and tuned to my specific car. i had to tune the bmw modules to my own liking so even an identical e60 like my car might not behave or work as mine. it is unfortunately a trial and error but for liability I'm not willing to participate into others life liability.
i will make a build thread for both cars i made and working. sharing the parts, mechanical and physicals mods, but when it comes to code i can do like i did with the shifter snippets to give you the good stuff but to make it actually work you at you your own liability.
for starters watch some of my very boring and long videos on YT
thanks,
Karim
Posted: Tue Dec 03, 2024 7:53 pm
by joeflickers
7yatna wrote: Tue Nov 12, 2024 6:04 am back to my previous comment.
thanks,
Karim
Does the zombie have protection against forward /reverse motor protection like the openinverter boards? What would happen if you switched reverse mistakenly while in drive-mode at high speed?
Posted: Wed Dec 04, 2024 10:56 pm
by 7yatna
joeflickers wrote: Tue Dec 03, 2024 7:53 pm Does the zombie have protection against forward /reverse motor protection like the openinverter boards? What would happen if you switched reverse mistakenly while in drive-mode at high speed?
I think this protection is implemented generally. But since there are multiple drive system zombie can support that protection is all the way down into the coding of each system code.
I didn't try or even looked for its code. But if it isn't it is a very easy function to add.
Just check real speed vs a threshold speed where direction can be changed.
I will look for it when I get around the code.
Posted: Thu Dec 05, 2024 7:15 am
by joeflickers
7yatna wrote: Wed Dec 04, 2024 10:56 pm I think this protection is implemented generally. But since there are multiple drive system zombie can support that protection is all the way down into the coding of each system code.
Now that you mentioned.. I did try it in my car using gs450h + zombie software version 2.17 speed around 1000rpm and indeed im able to switch to reverse instantly.. This can be fatal I believe at high speed?
Posted: Thu Dec 05, 2024 7:18 am
by joeflickers
To also add.. I've updated my ecu with version 2.20.. Same parameters settings as I've been using with version 2.17 and I realised the IVA-shunt is not reading the voltage.. Tried changing to CAN-1 and 2 and same results
Posted: Thu Dec 05, 2024 10:08 am
joeflickers wrote: Thu Dec 05, 2024 7:18 am To also add.. I've updated my ecu with version 2.20.. Same parameters settings as I've been using with version 2.17 and I realised the IVA-shunt is not reading the voltage.. Tried changing to CAN-1 and 2 and same results
Stop posting the same shit multiple times. PROVIDE INFORMATION if you need help.
Posted: Thu Dec 05, 2024 10:36 am
joeflickers wrote: Thu Dec 05, 2024 7:15 am This can be fatal I believe at high speed?
How do electric motors work? There is no physical gearbox. All that happens is the torque requests flip so you press more pedal going forward it will just increase the regen because its not spinning in the right direction.
Posted: Fri Dec 06, 2024 6:29 am
by joeflickers
tom91 wrote: Thu Dec 05, 2024 10:08 am Stop posting the same shit multiple times. PROVIDE INFORMATION if you need help.
appreciated, parameters changed in interface, had not selected ISA Shunt
Posted: Fri Dec 06, 2024 9:59 am
joeflickers wrote: Fri Dec 06, 2024 6:29 am appreciated, parameters changed in interface, had not selected ISA Shunt
Yes it can be that simple.
Again, why post this in somebody's build thread?!?
Posted: Fri Dec 06, 2024 6:06 pm
by joeflickers
tom91 wrote: Fri Dec 06, 2024 9:59 am Yes it can be that simple.
Noted.. He's been very helpful.. I'll be posting a different thread on my build
