Page 2 of 2
Re: MB100 1988
Posted: Tue Jan 14, 2020 3:29 pm
by urona
Does anyone have any information about the rear mitsubishi outlander motor and how the rest of rear axle is fixed.
Thank you
Re: MB100 1988
Posted: Tue Jan 14, 2020 4:14 pm
by Kevin Sharpe
urona wrote: ↑Tue Jan 14, 2020 3:29 pm
Have you seen this thread?
viewtopic.php?f=14&t=325
Re: MB100 1988
Posted: Tue Jan 14, 2020 4:35 pm
by urona
Interesting thread and there are some photos of the conversion on his Instagram. I like it
Re: MB100 1988
Posted: Tue Jan 14, 2020 4:38 pm
by urona
I think the mitsubishi outlander motor can fit at the front of my van....I will study this possibility
Re: MB100 1988
Posted: Wed Jan 15, 2020 4:23 pm
by urona
I found more information for the mitsubishi outlander, so...
- is it true there is to electric motor, one for each axles?
- it seems the weight of each is 40 kg, true?
- I didn't found a lot of information about the battery, weight and I'm sure it's 30 KW.
If anyone have some information, it will be perfect.
Re: MB100 1988
Posted: Wed Jan 15, 2020 7:24 pm
See a thread i setup to gather more info on Outlander rear motor
If you find new information please add to posts there.
Yes Outlander actually has three motors. In the front there are two motors inside transmission connected to gas engine.
In the back there is a single 60kW motor and inverter. This is more suited to conversion of small cars because of its size and compact gearbox.
Re: MB100 1988
Posted: Wed Jan 15, 2020 8:22 pm
by urona
arber333 wrote: ↑Wed Jan 15, 2020 7:24 pm
So it's meaning this solution seems not the best for my van, too heavy.
Maybe I need to consider to do that with the Lexus electric gearbox....
Re: MB100 1988
Posted: Thu Jan 16, 2020 6:12 am
by jnsaff
urona wrote: ↑Wed Jan 15, 2020 8:22 pm
It would be too heavy if you took only the rear motor of Outlander? Motor + inverter less than 100kg (same for Toyota transaxle). Lexus transmission alone is in the 120kg range? Also if weight is your main concern then the heaviest part would be batteries.
Re: MB100 1988
Posted: Thu Jan 16, 2020 6:33 am
I belive motor and gearbox has 60kg. Inverter has to be like 12kg so we are well under 100kg.
Where do you plan to put the batteries?
What is your practical application for the van? Do you intend to use it to ride around the country or do you intend to park it and use it as a summer house? You can use battery as power source for summer home like that.
Re: MB100 1988
Posted: Thu Jan 16, 2020 4:23 pm
by urona
When I wrote too heavy it was not the engine but for my van, I think my van it's maybe too heavy for the outlander.
Now I'm not sure if the two electric motor of the outlander are enough powerful for my van. It's why thought maybe use the Lexus electric gearbox???
Of course weight is important!!! So for the moment I'm studying all the possibilities.
In my project I would like to buy a scrap car, something broken, take what I need and sell the rest. Because I don't have a lot of money.
For the battery I have two spaces, in mm, 140x700x1600 and 140x700x1000, so enough, I think!! I'd checked on Alibaba just to have an idea and I found a model of lithium Ion battery : 3,2v - 105Ah - 201x131x37.2 mm. So 240 cells can be fit
The future application will be traveling. For this project I thought to install 2kwh of solar panels and 2 other kWh when we are parked, I know is not enough for charge all but it can help.
