Page 3 of 10
Re: The SuperYacht BMW E65 7 Series
Posted: Sat Dec 21, 2019 1:10 am
by mfox
that's great. :)
How much power is expected ?
Posted: Sat Dec 21, 2019 1:28 am
by xp677
Jack Bauer wrote: Wed Nov 13, 2019 8:53 am I think they changes to a newer type of inverter in 2009. LDH/RHD should make no difference. I do have a 2013 inverter that I plan on testing.
Old post, but if it helps, I'm using a 2007 inverter on a 2010 transmission and all is fine.
The model type ended in 2011.
Posted: Sat Dec 21, 2019 11:42 am
by Kevin Sharpe
mfox wrote: Sat Dec 21, 2019 1:10 am How much power is expected ?
Estimates are 220kW/300HP... we won't know for sure until we stick it on the dyno in the spring.
Over the next three months we will measure acceleration, top speed, test the dual speed gearbox, and validate cooling strategies. We will also get the car inspected by an automotive engineer, change taxation to electric drive, and get it through a national vehicle test.
Once all that's complete we'll put some miles on it as a daily driver and undertake some towing tests at the 2100kg car limit. Then it's long range battery, CCS rapid charging, etc., etc. :D
Posted: Thu Dec 26, 2019 7:40 pm
by mfox
excelent,
this is like small drive unit, but more sutable for RWD and cca 3x cheaper
yesterday I bought gearbox and inverter, can't wait when it comes. :D
Posted: Fri Jan 31, 2020 5:46 pm
by Kevin Sharpe
The Super Yacht (aka BEXUS) was inspected and passed by an automotive engineer today... next steps include changing the taxation class to electric drive, NCT, and testing on track and road 8-)
Posted: Fri Jan 31, 2020 6:03 pm
by Kevin Sharpe
Posted: Fri Jan 31, 2020 6:55 pm
by xp677
Nice. I'm using the same Tesla charger and TRW pump on my project :)
What are you using for a DC-DC converter?
Posted: Fri Jan 31, 2020 9:01 pm
by Alexstarex
xp677 wrote: Fri Jan 31, 2020 6:55 pm Nice. I'm using the same Tesla charger and TRW pump on my project :)
I think from Lexus 450
Posted: Fri Jan 31, 2020 9:12 pm
by xp677
I can't imagine that the GS DC-converter is suitable, as it's rated to 288v input.
Posted: Thu Feb 06, 2020 11:40 pm
by RE3Rotor
Is there a break down of the different components for the SuperYacht? I have a Subaru Forester I am looking to convert with the same GS 450h gearbox and is looking for information on this build.
Posted: Fri Feb 07, 2020 7:24 am
by Igor
Pretty sure it's all covered in his video series. But it wouldn't hurt to review them regardless.
Posted: Fri Feb 07, 2020 7:01 pm
by RE3Rotor
Igor wrote: Fri Feb 07, 2020 7:24 am Pretty sure it's all covered in his video series. But it wouldn't hurt to review them regardless.
From what I have gathered:
GS450h gearbox
GS450h inverter w/ his opensource control board
Tesla Gen 3 (?) charger w/ his opensource control board
I also would like to know if he has BMS with the batteries, and what else is inside that high voltage junction box.
Posted: Fri Feb 07, 2020 7:10 pm
by Kevin Sharpe
RE3Rotor wrote: Fri Feb 07, 2020 7:01 pm I also would like to know if he has BMS with the batteries
No physical BMS is used with the test pack (it's monitored manually). When the long range pack is fitted then I suspect it will use the BMS fitted to the modules (if OEM) or Johannes BMS.
RE3Rotor wrote: Fri Feb 07, 2020 7:01 pm what else is inside that high voltage junction box.
Contactors and Precharge relay/resistor.
Posted: Sun Feb 09, 2020 2:44 pm
by xp677
Can someone remind me, is the splined coupler for the transmission 21-spine, 28mm major diameter? For the wiki.
Posted: Sun Feb 09, 2020 4:19 pm
by Alexstarex
xp677 wrote: Sun Feb 09, 2020 2:44 pm Can someone remind me, is the splined coupler for the transmission 21-spine, 28mm major diameter? For the wiki.
Yes. all right
Posted: Sun Feb 09, 2020 9:01 pm
by xp677
Excellent, thank you.
Posted: Wed Feb 12, 2020 3:38 pm
by Kevin Sharpe
Look out for update video from Damien :)
Posted: Wed Feb 12, 2020 4:24 pm
Bexus Lives!!!!
Posted: Wed Feb 12, 2020 4:47 pm
So with today's testing of the Bexus (current weight 2050kg) and a crappy 450v battery that sags like a ton of bricks under load the car was pulling like a train up through 70mph up a hill. So imho we don't need 650v.
Posted: Wed Feb 12, 2020 5:12 pm
Thats super amazing. Who said electric motors can't have good sound ;)
I wonder how they react at road worthiness test.. sir, we can see a gear box but where is this cars motor?
Posted: Wed Feb 12, 2020 5:22 pm
by Zapatero
Love the sound, very cool. :D
Posted: Wed Feb 12, 2020 5:55 pm
by JaniK
Great sounds. That bexus is very good proof of concept!
Posted: Wed Feb 12, 2020 6:34 pm
by RE3Rotor
Jack Bauer wrote: Wed Feb 12, 2020 4:47 pm So with today's testing of the Bexus (current weight 2050kg) and a crappy 450v battery that sags like a ton of bricks under load the car was pulling like a train up through 70mph up a hill. So imho we don't need 650v.
What is the range for a 450V pack?
Posted: Wed Feb 12, 2020 6:45 pm
by sfk
RE3Rotor wrote: Wed Feb 12, 2020 6:34 pm
Voltage doesn't dictate range. Kilowatt hours is a better general indicator.
But weight of car, driving style, terrain and even climate factor into the range calculation.
Posted: Wed Feb 12, 2020 7:07 pm
by RE3Rotor
I guess a better question to ask is how much kWh does Damiens pack have? And that is driving the motors at all of 450V? Is there any boosting using the boost converter?
