GS 450H Web Interface
TonyV
Been thanked: 12 times
Post by TonyV »
Can the GS450H VCU Web interface with all the Parameters be access using Version V3_user.ino Software?
Has thanked: 11 times
Been thanked: 344 times
Re: GS 450H Web Interface
As explained in the video all except current and power are functional as these would require the isa shunt to provide this data.
TonyV
Post by TonyV »
Thanks for the reply,
But I must be asking the wrong question.
I see in other videos where You and Johannes changes settings. Where you adjust offsets, Charge currents, etc.
Are those setting/parameter available for the GS450H VCU?
I hope i make sense.
Quote from the wiki :
This firmware is intended as a stop gap measure before a new Openinverter based version with a web based interface becomes available. (expect mid 2021).
