Prius running on trolley lines (2014)
EV and openinverter related news
jnsaff
Been thanked: 8 times
Post by jnsaff »
When batteries are just too expensive...
https://thebolditalic.com/hacked-prius- ... cdbe55d68e
Has thanked: 176 times
Been thanked: 367 times
Re: Prius running on trolley lines (2014)
amazing. need more info! thanks for sharing
Has thanked: 379 times
Been thanked: 1559 times
The overhead power lines put out 600 volts at around 400 amps ... The NiMh battery that does the heavy lifting in a normal Prius puts out 273 volts at 6.5 amps. Jon uses up the excess power on a whole lot of resistors
And I'm screaming: that what buck converters are for!
Pretty cool you can actually drive around in this, I bet in Germany they'd shut you down on the first day out.
Peakon28
Has thanked: 6 times
Post by Peakon28 »
Wow this is amazing
