Tesla M3 batteries
boekel
Been thanked: 24 times
Tesla M3 batteries
Post by boekel »
Hi all,
I have some Model3 batteries that I'm not using yet...so want to part with some...as it adds up fast...
Prices ex tax (if applicable) and they are based in NL
short range is probably 50 kWh (not sure, might be more) long range 75 kWh
I have a 'short range' with 'long modules' that is partly disassembled (bms boards partly removed and sent to Damien)
€1000 / module (23/25s modules I think?)
short range 'short modules' (much more compact, and 4x the same voltage), disassembled but complete
€1300 / module (24s modules I think)
short range - still closed, judging on COG (Center of Gravity) also short modules
€5200 / complete battery with some wiring / coolant pipes
long range - still closed, comes with all wiring incl. charge port! (30k km or 50k km)
€8000
jnsaff
Been thanked: 8 times
Re: Tesla M3 batteries
Post by jnsaff »
Would you have the dimensions for the short range 'short modules' roughly and a guess of the weight? Also for the unopened batteries, is the penthouse and PCS included?
boekel
Post by boekel »
Hi @jnsaff
length: 1370 incl. connections
width: 340
height 80
connection on one end extends about 90mm (included in the 1370mm length)
boekel
Post by boekel »
Weight: 59 kg's / module
