Type 1 Charging Port from Nissan Leaf 2014
Zapatero
Has thanked: 27 times
Been thanked: 58 times
Post by Zapatero »
Up for Sale is a Type 1 Charging Port from a Nissan Leaf. It served me very well in my GT86 conversion. Now i have a wallbox with a attached type 2 cable so i changed the socket from type 1 to type 2.
There is a 3 phase silicone wire soldered to the original Leaf cable. It is approximately 4 Meters long over all. I also had to solder small gauge wires to the two ac lines as i used a tiny 230v to 12v converter to supply 12v feed while charging. The CC and CP cables are there, too. There is a carbon fibre adaptor ring around it, but you can take this off, if you like. So it's ready to go into another conversion straight away.
Looking for 99€, shipping worldwide possible.
Located in Dornstadt, Germany.
