Openinverter SDU board, contactors, and inductance [SOLVED]
- catphish
- Has thanked: 98 times
- Been thanked: 195 times
Sorry if this is a FAQ. When using the open source SDU board, is it necessary to place flyback diodes across the contactors, or does the board completely protect against the contactor coil inductance? Obviously adding the diodes is easy enough, but I wanted to confirm whether this was necessary.
- Has thanked: 382 times
- Been thanked: 1574 times
Re: Openinverter SDU board, contactors, and inductance [SOLVED]
It varies. Some boards have specialized drivers with overvoltage protection (BTS133) but some don't if these weren't in stock. Just use a diode to be sure. Or check the printing on the drivers.
