I have in my garage a Marina Coupe its started life as a 1.3 with a 4 speed gearbox.
I have two 7.5kw A/C Motors and would like to mount one directly on to the rear differential flange.(with cradle made up to lock it to the rear axle)
I plan to get a flange made up to suit the diff flange.The rear axle is from a Triumph Dolomite Sprint.Further plan for the rest of the car is using a Nissan leaf battery charger and inverter
and whatever battery is available when the time comes.
but I am unclear how to set up a resolver for the A/C motor. does it attach to the outside (fan) end of the motor.
Any help would be very much appreciated.
Regards Gary
Marina Coupe 1976 Vintage
- Bratitude
- Has thanked: 180 times
- Been thanked: 374 times
Re: Marina Coupe 1976 Vintage
What is the diff ratio? I’m not sure you’ll have enough gearing to appropriately move the vehicle.
there’s many different resolver “kits”, you may be able to find a “resolver bearing” and replace one of the rotor bearings with one.
4.1to 1 is the diff ratio on the sprint axle from what i can tell on the forums
Regards Gary
I have the old marina axle if the sprint is too tall
Regards Gary
