Remote IO / MAX17841 CMC Master for Zombie VCU / SIMP BMS
EV_Builder
Post by EV_Builder »
In addition to the TayCan version i also am building the MAX17841 version of the device.
List of compatible batteries/slave BMS boards will be added below:
  • - Hyundai Ioniq Kona will be the first one.
dimonlipko
Has thanked: 7 times
Been thanked: 10 times
Re: Remote IO / MAX17841 CMC Master for Zombie VCU / SIMP BMS
Post by dimonlipko »
I have Hyundai Ioniq bms, i can help you with reversing it.
EV_Builder
Ok today I have received first batch of boards. And a Kona device setup it seems..
EV_Builder
Good progress here. Comms with the chip are working.
So next phase is writing code with the commands to init and read out the cells etc.
If someone already figured out the connections to the Kona slaves..; I'm all ears :)
EV_Builder
dimonlipko wrote: Fri Sep 09, 2022 7:43 pm I have Hyundai Ioniq bms, i can help you with reversing it.
Ok do you got the slaves too?
dimonlipko
Yes, i have slave and master unit.
EV_Builder
Ok since sunday i have the comms all working so i'm done.
It's now time to update the GUI of the product so it reflects the correct values next step will be adding BMS functions etc.
