Wanted ISA Ivt-s shunt UK
Posted: Mon Aug 22, 2022 12:49 pm
by Ev8
As title really can’t find one anywhere
Re: Wanted ISA Ivt-s shunt UK
Posted: Mon Aug 22, 2022 11:07 pm
by Zapatero
i've got one here in Germany - i can send it to the UK of course!
Posted: Tue Aug 23, 2022 12:53 pm
by Ev8
Please send me a message with the price
Posted: Fri Sep 30, 2022 6:40 am
by Jonr
I'm in the market for an ISA shunt - does anyone have one available or can suggest the best place to find one?
Posted: Fri Sep 30, 2022 6:48 am
Jonr wrote: ↑Fri Sep 30, 2022 6:40 am
I have one shunt only from Jaguar. It is a 500A version without voltage sensing. I am offering it for 80€ + shipping?
I guess it would need to be reprogrammed too. See here:
viewtopic.php?t=1282
Posted: Fri Sep 30, 2022 7:59 am
by aot93
I contacted the UK distributor for these.
They came back with £288.10ea plus vat for 10.
In stock at manufacturers.
So probably the same as getting from existing EU suppliers.
Posted: Fri Sep 30, 2022 9:07 am
by 4markowen
https://www.testco-inc.com/search/manuf ... /mId:20907
if the £ pound hadn't tanked against the $ these would be reasonably similar in price including shipping, etc.
Seems getting one at the moment is around £300.
Posted: Fri Sep 30, 2022 10:12 pm
by Jonr
Today, I took delivery of a power pack from a BMW 530e which apparently includes a shunt..... could the ZombieVerter be enhanced to support this shunt in addition to the ISA, assumng they are both controlled CAN messages?
Posted: Sat Oct 01, 2022 8:21 am
by Jonr
Jonr wrote: ↑Fri Sep 30, 2022 10:12 pm
EDIT:
I've just realised there is the mapping function on the ZombieVerter
https://openinverter.org/wiki/File:Spot_values.png
Has anyone used this to be able to use the BWM shunt in place of the ISA shunt?
If so, how?
Posted: Sat Oct 01, 2022 10:15 am
There is also LEM CAB500 current sensor on can bus. They can be found in Outlander packs...
Posted: Sat Oct 01, 2022 11:44 am
by Ev8
Ok I now have what I needed thanks
Posted: Sun Oct 02, 2022 2:15 pm
by larsrengersen
The beauty / advantage of the IVT is that some models (including the one used with the Zombiverter) that can measure both voltage and current.
I have the 1000A in stock.
For current only you can use cheaper sensors like
this current only IVT or the CAB by LEM or others perhaps.
But then the question is: how to measure voltage and get it send on the CAN bus?
Plus of course the firmware change needed in the Zombiverter.
Posted: Thu Oct 06, 2022 5:28 am
by asavage
IDK, a IVT-S-500-U3-I-CAN1-12/24 is still USD$265, which isn't really a whole lot less than £300 in my view.
Posted: Tue Jan 03, 2023 11:03 pm
by FFMan
I'm also looking for a shunt for SOC calculation. I have a V1c board not zombie so will do SOC on arduino based on data I harvest.
> or current only you can use cheaper sensors like this current only IVT or the CAB by LEM or others perhaps.
As i understand it SOC is based upon measure Amp-seconds. I can get voltage from the Outlander charger can bus and I think this is pretty accurate as you might expect it to be so would this currnt only shunt suffice - it's a lot cheaper.
Posted: Tue Jan 03, 2023 11:11 pm
by asavage
Last week, I just received one from member pablo_mtl, USD$155 including shipping (Canada->USA).
viewtopic.php?t=1338
The one I received has a non-terminated CAN, which is more flexible for implementation (just add 120R to the back of your CAN connector, if you need termination at the shunt).
Posted: Sun Jan 22, 2023 3:35 pm
by jcwright45
Anyone still in the market for shunts? I have 2
Posted: Mon Mar 06, 2023 10:08 pm
by TonyBM
have you still got the shunts? hope so
Posted: Fri Mar 24, 2023 10:41 pm
by modellfan
jcwright45 wrote: ↑Sun Jan 22, 2023 3:35 pm
Still available? How much do you want for one?
Posted: Tue May 09, 2023 9:15 pm
by langoo
I'm on the hunt, PM me if you have one left.
Posted: Thu Aug 17, 2023 6:18 pm
by Galileo241
Hey guys, anyone here who has already tested and used their new sensor IVT 3.0?
https://www.isabellenhuetteusa.com/prod ... -0-series/
Does anyone offers the same? Can’t find it on digikey or mouser.
Appreciate your help!
Posted: Mon Aug 21, 2023 10:01 am
by jnsaff
It looks like they only send evaluation devices out for now.
Posted: Thu Aug 24, 2023 9:41 pm
by larsrengersen
They are at B2 Sample stage.
Not end user configurable yet like the normal IVT and already much more expensive.
I’m awaiting of the final product release and they will inform me once I can order those.
Posted: Thu Aug 31, 2023 12:26 am
by asavage
This fellow has three of the 300A version, @ £99 ea. and is located in the UK:
https://www.diyelectriccar.com/threads/ivt-s-can-current-sensor-shunt.209220/
I would think the 300A capacity would work OK for situations where one is adding DCFC and using the BMW i3 LIM setup or similar.
