Is resolver needed powering a pump
eprotiva
Post by eprotiva »
I have a gen 3 prius inverter and leaf em61 motor that replaces a 50 hp engine. Do I need the resolver? I’m going for simplicity and reliability.
Ev8
Has thanked: 44 times
Been thanked: 172 times
Re: Is resolver needed powering a pump
Post by Ev8 »
Short answer yes, there are other sensorless controller’s out there that could do the job without, but for an OI control board it’s a must. Yes you could probably make it spin in manual mode with the sine software and no resolver, your not going to get the torque control you need for a pump without using the resolver and the FOC software
