Could anyone provide advice finding a charger from an OEM that could be found fairly easily?
Very low power would be fine, I'm just hoping for the smallest form factor possible, since this would hopefully be for a motorcycle.
350V max pack voltage.
Small form factor charger
- Has thanked: 145 times
- Been thanked: 369 times
Re: Small form factor charger
I have seen 3.3kW TC charger (Elcon). It is really small form factor and can be setup for your exact battery config. You can have CAN flavour or just plug and play.
Also liquid or air colled.
https://evshop.fr/en/chargers/224-8351- ... 61292.html
Only Eltek 3kW chargers would be smaller form factor for a bike. You can get them from Eltek or in Volvo V60 hybrid cars. viewtopic.php?t=2580
Yah, you're probably right that will prove to be the best solution.
I was hoping against hope for something even smaller, since that charger is what the motorcyle came with from the factory in a big waterproof pelican/brief case.
Edit:
Oh shoot, missed the part about that Volvo charger. Thank you!
Edit:
