Prius inverter as a DC source ?
EvPrud
Post by EvPrud »
if I connect a three-phase diode bridge and a capacitor to the output of the inverter, can I get a regulated DC voltage at the bridge output ?
Been thanked: 1914 times
Re: Prius inverter as a DC source ?
With the motor control firmware you won't as there is no voltage regulation.
You can try this firmware https://github.com/jsphuebner/stm32-island
It uses the boost converter to generate a regulated DC voltage which of course must be higher then you input DC voltage. So then you can tap regulated DC voltage right off the DC bus instead of first inverting and then rectifying it.
Romale
Has thanked: 346 times
Been thanked: 101 times
Post by Romale »
johu wrote: Sat Jan 07, 2023 2:17 pm With the motor control firmware you won't as there is no voltage regulation.
is there an option to make a variable 380 of three phases or 220 between two phases?
evil neodymium :twisted:
