MQB & MLB Can log Request - For Zombieverter Comm Additions
Mitchy
Has thanked: 4 times
Been thanked: 70 times
Post by Mitchy »
Hey All.
Wondering if anyone has any sources for a MQB and MLB canlogs.
I have the DBC files already, but just looking for some examples to work with to write a Zombieverter CAN plugin for MQB and MLB models.
Lots of shared addresses between these two, as well as the Porsche 9x1/Macan. I've got the 9x1 codebase pretty much ported over as a start.
Overall there'll likely be a unified 2010 VAG selection, with switches to choose the MQB/MLB/9x1 implementations.
I don't intend the code to be elegant, but it'll be a good basis for refinement for the community to work on.
RetroZero
Has thanked: 564 times
Been thanked: 54 times
Re: MQB & MLB Can log Request - For Zombieverter Comm Additions
Post by RetroZero »
Will be a while, but I'm waiting to see what Damien hacks up with his CAN data logger and getting one asap.
RetroZero
Post by RetroZero »
Got savvycan running with wifican @uhi22. Crocodile clip arrived. I'll see if it can be used for CAN logs. I tried it on a bench setup cluster and the data seems identical to the hardwire setup with wifican.
Edit - my crocodile clip is not yet operational. The data I'm seeing is from the hard wire setup.
Edit - 2, Got another Canadapter board on its way to connect independently to my bench setup and see what the crocodile says 🤞
RetroZero
Post by RetroZero »
Trying in another thread.... Capturing CAN data sent with VCDS and then playing it back (blinking LED on charger flap), I can't get the LED to blink. Are the magic bytes required when playing back CAN data? I tried it with the lock actuator too.....
Has thanked: 421 times
Been thanked: 121 times
Post by Jacobsmess »
Hi Mitchy, did you get any Canlogs from an MQB vehicle? thanks
uhi22
Has thanked: 206 times
Been thanked: 617 times
Post by uhi22 »
Is it clear which of the CAN busses is of most interest? AFAIR there are multiple, like engine CAN, body CAN.
And do we know where contact them?
uhi22 wrote: Tue Feb 04, 2025 7:30 am Is it clear which of the CAN busses is of most interest?
For myself I suspect only the powertrain can is required but I have revived an old thread from 2023, not sure if Mitchy answered his question or not.
