Prius gen3 logic board missing MAX735
Mhs
Has thanked: 211 times
Been thanked: 9 times
Post by Mhs »
Hello, I have received Prius gen3 logic board from evbmw webshop and it's missing the max735csa which I believe due to components shortage. Question is does the max735csa+ which is available to buy is considered a suitable replacement?
Zombieverter
Pajero 1990
Pete9008
Has thanked: 102 times
Been thanked: 350 times
Re: Prius gen3 logic board missing MAX735
Post by Pete9008 »
The datasheets for both parts on both digikey and Mouser seem to link back to the same datasheet for the max735csa so I'm assuming that they are equivalent.
The max735csa is marked as obsolete and the max735csa+ as current so I'm guessing it is just the replacement. Only way to be sure is to fit one and test it!
Mhs
Post by Mhs »
Pete9008 wrote: Wed Feb 22, 2023 1:17 pm The max735csa is marked as obsolete and the max735csa+ as current so I'm guessing it is just the replacement. Only way to be sure is to fit one and test it!
Thanks Pete, I went ahead and ordered it!
Zombieverter
Pajero 1990
