mikejh wrote: ↑Wed Apr 19, 2023 6:07 amIn order to get an induction motor that's made for 50hz to run faster you have to make that AC 100hz, 200hz, 400hz etc to get the higher rpm.
Yes, I'm following you.
Now you have to synthesise an AC sine wave at 400hz using a chopped DC (pwm) frequency at say 8khz.
Right. So, the faster your frequency, the less... I dunno, "resolution" you have on the inverter side, to imitate a sine wave smoothly? Is that the problem?
8800 / 400 = 22. So in that example we have only 22 steps per cycle (or, half that, to hit both halves of the cycle?), and that starts getting too lumpy? And... things happen... when lumpy?
And, for example the OEM Prius motor would never need that high of frequency? Or, it doesn't count, because things are different there?
I think there is a limit to the upper sine wave frequency for a given pwm frequency and inductance of the motor starts to affect it too.
Mmm, yeah, I think you and me both hit the confidence wall here as to what happens next.
Something something, too fast, inductance, no worky no more.
arber333 wrote: ↑Wed Apr 19, 2023 7:43 amI think with current IGBTs you can get up to 400Hz in frequency using 14kHz carrier PWM.
This is where I've lost you. Why? I understand "inverter gets too hot", but... why?
Also, do we know that the 1000 RPM my motor gets is at 50hz? Is it linear to go faster?
The diff is a 3.44:1 ratio, I'll direct drive. With stock everything, 3500 rpm gives almost exactly 70 mph in an Opel GT. That's probably the upper end of where I'd drive it. Maybe I'd like to hit 80, but I'm not a teenager, I'm not street racing with it and I won't have the battery capacity to get home if I did.
So, 3500 RPM looks like a nice goal. Is it true to say that I need 3.5x 50hz = 175hz? (plus some extra, to account for slip?).
And, if so, is 175hz something a lot less intimidating to the Prius inverter and something it can handle?
But i think you can still use this motor with some 120Vdc and there would not be much consequences. Maybe you can rewise you intended battery from 96S to 32S3P to get 115Vdc? Just an idea...
Oh, I'm a special case, I've got way more flexibility than that.
Lower voltage is easier in every way. I was almost headed the other way, since I'm one of the very few who can have a small kWh but high voltage pack, as I'm making my own from 18650s. I'm not constrained by the minimum building block size like most other people are. I have thousands of cells, not just 96. I can pick any voltage I want.
It's why I was still half-considering the Toyota Highlander MGR rear end, since no one else has a 600v pack to ever run one in a car light and small enough that the MGR could still push it. I kinda want to get this motor working (as the "easy" option), and while driving, work on replacing the whole rear end and do a swap. So at least I get some joy of driving rather than endless featurecreep.
I was even thinking, since the Prius inverter can handle 600v, why not just give it 600v, or, maybe 300v now, and, in case I want more range but can't get more 18650s (my free supply went out of business 3 years ago), build them to an AH rating that could be supplemented by larger form factor cells in the future (Leaf or whatnot), continuing in series. I guess that's shot, and I should stop at 200v at most. Any reason not to just target the ~208v that the OEM Prius pack had?
The problem is i am not sure your Prius inverter drivers would work that low. I think that would merit a test?
Well I ran it at 12v. It spins. I don't know if that answer the question or if I'm missing something.
It needs ~190v minimum to power the DC/DC but, that's a tertiary concern (I'll just use the onboard boost converter to boost the 120v to 200v so that the DC/DC can buck it down to 12V! ... ). Or, umm, a just buy a DC/DC.
Pete9008 wrote: ↑Wed Apr 19, 2023 10:00 amCan't comment on the RPM the motor can physically stand but the inverter should cope.
Hurray. That was easy. Pete said so, no take-backs!
Just because no one else has mentioned yet and it might too be a game-changer... how bad is my efficiency going to be by overdriving this motor compared to its comfortable level of 50hz?
On the voltage I think the main limiting factor is the winding insulation.
Hmm... I'm less concerned about that. It's a fairly modern motor (2005-ish?) and I'd imagine all enameled wire is going to be thick enough to be "enough". I'd doubt they used special thinner enamel than they would've used for, say, I dunno, 600v industrial motors. It probably all comes off the same reel, right? Maybe?
Maybe I'll give everything a laquer spray to it all to discourage arcing.
If you parallel MG1 and MG2 could you get 500A? If so then 115V would give 57kW (I might be tempted to push a bit higher on voltage to get a little more power).
I don't think I can parallel MG1 and MG2. My board wasn't built for that. Unless I can just shove all the MG1 stuff in parallel with the MG2 wires? (MG1 shutdown, MG1 U/V/W phase signals, GFIV fault).
When I read that, I understand it, but I know I do at a shallow level. I don't think I could apply it and correctly problem-solve anything.
Mike if I'm hijacking your thread too far let me know and I'll fork off to my own.
