i am using ev200 contactors on my main battery feed and all is ok. Now i am ready to install another battery pack and tidying up the install.
As i have a couple of ev100 contactors in the parts bin, could i use these on the precharge circuit, and keep the ev200s for postive and negative. I assume the precharge resistor is limiting the inrush to well under the ev100 rating ?
Contactor ratings
FFMan
- Has thanked: 9 times
- Been thanked: 50 times
Contactor ratings
- rstevens81
- Has thanked: 29 times
- Been thanked: 114 times
Re: Contactor ratings
Ev100 could also be used for fast charging or switching hv heater on/off but OBS the 100 would mean the continuous current rating. Using it for precharge you could get away with forgoing the economiser as it should hopefully not get too hot
Edit Voltage = current X resistance & power = voltage X current
kylestewart
Thank you for your formulas. It worked.rstevens81 wrote: ↑Thu Aug 17, 2023 5:38 pm Ev100 could also be used for fast charging or switching hv heater on/off but OBS the 100 would mean the continuous current rating. Using it for precharge you could get away with forgoing the economiser as it should hopefully not get too hot
Edit Voltage = current X resistance & power = voltage X currentrooftop snipers
