Just working on resurrecting my EV, and the BMS attached to my front battery pack isn't reporting voltages anymore. The canbus part is working as i can see the modules report in, and i send the commands to it, but it doesn't respond with the voltage messages
The rear pack is working just fine, same code etc
Did i see somewhere a need or code to reset the sequence ID ?
thanks
BMW BMS gone quiet
FFMan
- Has thanked: 9 times
- Been thanked: 50 times
BMW BMS gone quiet
- Has thanked: 330 times
- Been thanked: 848 times
FFMan
Re: BMW BMS gone quiet
i don't have a can log, just my debugs at the moment.
I'll get a log, but battling to get a canbus to usb adapter working at the moment. bought something which shows up as 'candlelight usb to can adapter' in device manager but i can't get savvycan or cangaroo to use it. it needs more work or even a f/w flash
