Battery Service disconnect
Posted: Mon Dec 30, 2019 11:46 am
by doobedoobedo
I'm currently looking for a service disconnect, any suggestions for where best to source it?
I'm also considering placing my contactors in the centre of the battery so as to isolate the two halves when switched off, are there any downsides to this?
Re: Battery Service disconnect
Posted: Mon Dec 30, 2019 11:56 am
by SciroccoEV
Usual arrangement is contactors on + and -, with disconnect in the centre, but that's with a monolithic pack.
If you can't salvage a disconnect, then you can make your own using off the shelf connectors.
https://www.dalroad.com/products/electr ... omponents/
Posted: Mon Dec 30, 2019 12:58 pm
by Kevin Sharpe
Lots cheap Tyco parts around if 350A 690V is acceptable;
https://www.ebay.co.uk/itm/Battery-Disc ... 3958085070
Posted: Mon Dec 30, 2019 2:20 pm
by doobedoobedo
Awesome thanks Kevin. Pretty much exactly what I was looking for, just didn't have the correct search terms.
Still value some additional input on contactor placement.
Posted: Mon Dec 30, 2019 2:53 pm
This is the: 1-2103172-2 I believe, might however be a different keying not too sure. datasheet:
https://www.mouser.co.uk/datasheet/2/41 ... 758279.pdf
https://www.te.com/usa-en/product-2-2103172-7.html
You need a mating part for this one.
https://www.te.com/usa-en/product-1-1587987-7.html
Available from mouser :
https://www.mouser.co.uk/ProductDetail/ ... FySbgWDw==
if you need a beefier one, Zero-EV just got one to take 400Amp Continuous and up to 1200Amp for a couple of seconds.
https://zero-ev.co.uk/product/hv-fuse-4 ... isconnect/
Posted: Mon Dec 30, 2019 2:59 pm
doobedoobedo wrote: ↑Mon Dec 30, 2019 11:46 am
Do you have one physical enclosure? If so, the best practice is to have the contractors at either end of the pack positive and negative, this way none of the bits outside the box are 'live'.
You can always ofcourse create a setup with a mid contactor that switched in sync with the negative contactor.
In case you do not have a single box best practice would dictate a contactor per box, and a disconnect and fuse per box. This is to ensure you never make a connection/damage a cable that will directly short out one box without a dedicated fuse.
Posted: Mon Dec 30, 2019 3:46 pm
by doobedoobedo
I'll see when it arrives, but it may also be
https://uk.rs-online.com/web/p/electric ... s/8086762/
I also have a separate 400A fuse so I may replace the one in the disconnect with a shunt and use that. I'm hoping to be able to push up to around 500A through it for a couple of seconds.
tom91 wrote: ↑Mon Dec 30, 2019 2:59 pm
All connections will be enclosed, I don't have boxes as yet as I haven't completed working out the layout. I'll have 10 10S modules and was going to put the contactors so that nothing was over 200V unless the system was fully live. If there's a good reason not to do this then I'll change it.
Posted: Mon Dec 30, 2019 4:52 pm
You can use already available parts like this one.
https://www.ebay.co.uk/itm/Chevrolet-Vo ... 2461662235
I have one just like it and will install it on one rail. if some day i get more powerfull battery i can install another one alongside it.
Posted: Mon Dec 30, 2019 7:18 pm
by doobedoobedo
Cool another option. Ampera/Volt stuff is like hen's teeth in the UK.
