I just setup the electric vacuum pump to the cars original brake servos to check if vacuum can be made. the car is 51yrs old now ( 1973 bmw)
I was quite happy as the pump did shut down , it lasted about 2mins before restarting again, ( not using a reserve tank, straight to the servo) thought that is was good, but not sure now ?
In a ICE engine the vacuum is constantly being made when the engine is running.
Is it good ?
If you have this setup in your build , does it do the same as mine
