what sort of contactor
D@F
Has thanked: 6 times
Post by D@F »
hi all, i'm on the choice of different contactor.
i'm planed to use the chager function of the brain board.
i see on the schematics (buck mode) some of them must be in 12v and other 240vac.
did the signal from the board could drive directly the contactor ?
i think the max current will not be over 40A.
wich contactor do you use ? and where do you buy them.
i think for some of them i will use smaller one (k5 and K1) because the space inside the original controler start to be small....
