I have two of these for sale, 5.6kWh each, would prefer to sell them together
One battery module is perfect, the other I accidentally bent one corner of the conductor plate when pulling it out from under a pile of them, which then snapped about a dozen of the tiny fuse wires. All 444 cells are fine, but the cells with the broken fuse wires do not have contact with the conductor plate any more, so as is, the battery has its capacity reduced by about 20%. This pack was not charged or discharged since I did the damage
Picture is of the damaged corner of the bad module
Fine to use as is (with a BMS of course) or for someone to re-do the fuse wires. I don't have the skills or the equipment to do that. Or you could even salvage the 444 Panasonic battery cells from it if you have other plans with them
I still have 12 of these modules in everyday use powering my house. They are from a low mileage 2015 Tesla Model S and have at least 90% of the original capacity, going by some tests that I did
Price (or nearest offer)
bad one €395
good one €695
both €995
Collect in person only from me in Dublin, Ireland. If I got a strong offer, I would consider selling all 14 modules
