Upload failed? get spinning wheel.
joromy
Post by joromy »
Continue from here:
viewtopic.php?f=7&t=563#p7016
Yes will certainly do fresh update of ESP module firmware and SPIFFS.
How do I know what version of ESP firmware SPIFFS I have?
Been thanked: 411 times
Re: Upload failed? get spinning wheel.
joromy wrote: Sun Feb 23, 2020 9:03 pm How do I know what version of ESP firmware SPIFFS I have?
Your case was similar to mine a year ago. It also locked up Olimex and i had to upload firmware through ST-link. ESP and spiffs were one of the first i got from Johannes. Not updated.
dima
Post by dima »
Since you have your custom board, maybe you have something similar to Damien's issue with Tesla board.
joromy
Post by joromy »
Thank you, Have got the board reflashed with ST-link, and it's working again.
I will remove the resistor anyway.
Have followed the olimex setup with 10k/0.1uF reset, have this issue come up with the olimex boards to?
Have updated the ESP module and u/l new SPIFFS.
I'm not able to get the same error, have tried several times.
So this fault seems to be to old inverter firmware.
