Charging with VCU isn´t possible
medo
Has thanked: 21 times
Post by medo »
Hi, I wanted to charge it and apparently the VCU is interfering with the charging, as soon as I unplug the VCU, it can be charged again without any problems, I installed the Tesla gen2 OBC.
I've added the parameters of the VCU and the charger, a CAN log is also included
In the Orion BMS2 is chademo aktivatet
teslaG2_param.json
(220 Bytes) Downloaded 94 times
vcu_param.json
(1.96 KiB) Downloaded 103 times
withVCU.csv
(1.7 MiB) Downloaded 102 times
withoutVCU.csv
(3.91 MiB) Downloaded 103 times
robertwa
Has thanked: 145 times
Been thanked: 195 times
Re: Charging with VCU isn´t possible
Post by robertwa »
Have you tried putting your charger onto a different CANbus?
