Opel Ampera Aux battery control
Posted: Thu Jan 02, 2025 2:07 pm
Up to winter 2024 our Ampera chewed through two AGM 12V aux batteries...in couple of months!
Seriously! I knew Ampera and Volts were though on Aux batteries but that is too much.
When i bought new AGM i went to observe what is happening and connected Torque pro and observed, Characteristic was real killer. DCDC directly at start would push 15V and about 135A into NEW battery! I could agree that is a shocker.
That torture lasted about 10min and then DCDC subsided to 14.4V to 13.8V during some 30min. That would be ok, but later this charging just ended and DCDC failed to charge with battery dropping down to 12.7V during normal highway operation!!! Which is eqally shocking. Therefore i can conclude that Ampera forces the aux battery to go through one full cycle during EACH drive!
I would imagine this would kill or seriously weaken AGM batteries quickly.
So what to do next...
You may remember i published how i made DCDC to work outside Ampera car.
https://leafdriveblog.wordpress.com/201 ... dc-or-apu/
I can see i have two options here:
1. I can add VCU with CAN bus which would simply request 14V from DCDC whenever its Enable line will be ON.
This does not include of listening DCDC report. I would simply request 14V and leave it at that. Lets see what happens...
2. I could add more complex VCU with 2 CAN buses and make it work as a middleCANman. I would use primary CAN to command DCDC and read its report, Then i would read command from the car on secondary CAN channel and transmitt the corrected report for the car to satisfy its systems.
That will require much more sophistication and programming loops.
