Zombiverter VCU Charging Cut-Off Guidance Topic is solved
maiks
Has thanked: 7 times
Post by maiks »
Hello,
I have a Zombiverter VCU and a 3.6kW Leaf PDM that I am using to charge a battery pack. The battery is supposed to be 72kW when fully charged (400V * 180Ah) and 64kW at nominal voltage (355V * 180Ah). However, when charging with the EVSE set to 15A, I noticed that the current drops to around 1.5A once the voltage reaches 355V and does not increase beyond that. Could you help me understand what might be causing this issue? I have attached a copy of my parameters for your reference.
my_params.json
(2.13 KiB) Downloaded 496 times
Has thanked: 209 times
Been thanked: 572 times
Re: Zombiverter VCU Charging Cut-Off Guidance
Please provide a CAN log too.
Also what generation of Leaf PDM? What is the battery pack and BMS?
maiks
Post by maiks »
tom91 wrote: Tue Mar 11, 2025 11:55 am Please provide a CAN log too.
gen 2 PDM, l connected 24 catl modules (4S1P, 180Ah,nominal voltage 14.8) and leaf BMS. Am going to log CAN later and l send
Has thanked: 176 times
Been thanked: 369 times
maiks wrote: Tue Mar 11, 2025 12:05 pm gen 2 PDM, l connected 24 catl modules (4S1P, 180Ah,nominal voltage 14.8) and leaf BMS. Am going to log CAN later and l send
If u disconnect the bms, will it keep charging? What size battery was the bms from?
You set "BMS_Mode": 0
Yet you have a Leaf BMS?
What firmware version are you on?
maiks
Post by maiks »
Bratitude wrote: Tue Mar 11, 2025 1:52 pm If u disconnect the bms, will it keep charging? What size battery was the bms from?
I disconnected the bms. It was a 24kw bms but am planning to buy flying ADC bms
maiks
Post by maiks »
tom91 wrote: Tue Mar 11, 2025 1:56 pm You set "BMS_Mode": 0
I disconnected the bms . Am using the latest firmware 2.20A
maiks
Post by maiks »
I've finally figured out the problem—it was with the EVS. After replacing it, the charging works as expected
