Motor Judders in drive
manj3000
Post by manj3000 »
Hi all i have a leaf gen2 stack with leaf throttle running on the zombieinverter, i calibrated the throttle and everything powers up ok.
When i run the system in reverse everything is nice and smooth but lacking a little torque but when i switch it to drive the motor judders without straight away without touching the throttle, when you press the throttle it spins up but then starts fluctuating. when you let the throttle off it starts juddering again.
Any help would be great
I would put up parameters file but i don't know how to
LRBen
Has thanked: 75 times
Been thanked: 217 times
Re: Motor Judders in drive
Post by LRBen »
Sounds like you have it running on the bench? It will act like that when it's unloaded.
manj3000
Post by manj3000 »
Hi its installed in the vehicle and it does the same, we have not tried it in gear yet but will do on Monday and see what happens
Parameters attached
params (1).json
(1.96 KiB) Downloaded 12 times
LRBen
Post by LRBen »
I would set regen to 0 for now. Then add it in slowly when it's driving to suit your tastes along with regen ramp which looks too high for now as well.
Also change throtramp to 5.
Rustybkts
Has thanked: 17 times
Been thanked: 7 times
Post by Rustybkts »
The latest firmware release v2.22a has a weak reverse which I assume will be fixed on the next one.
Beware of throtramprpm and leave it set to 20,000 as any rpm over a lower setting allows full power uncontrolled acceleration as I found when setting it to 1000.
Seriously scary!
Has thanked: 204 times
Been thanked: 556 times
Rustybkts wrote: Tue May 20, 2025 9:53 am The latest firmware release v2.22a has a weak reverse
All releases have this. Not just this one, it wil be solved in the future.
manj3000
Post by manj3000 »
Thanks for all the info got it working ok and got around the reverse for now
Has thanked: 384 times
Been thanked: 109 times
Post by Jacobsmess »
What was the issue?
