CAN Callback - Zombieverter VCU
modellfan
Has thanked: 20 times
Been thanked: 61 times
Post by modellfan »
Am I wrong, or is there an danger to not be able to use the same CAN ID on two different CAN Buses by the way, the callbacks and filters are currently implemented. The callback function is called no matter on which bus the data is recieved. Then only for the ID is filtered and not for the bus:
    canInterface[0] = &c;
    canInterface[1] = &c2;
    c.AddCallback(&cb);
    c2.AddCallback(&cb);
    TerminalCommands::SetCanMap(&cm);
static bool CanCallback(uint32_t id, uint32_t data[2], uint8_t dlc) //This is where we go when a defined CAN message is received.
    dlc = dlc;
    switch (id)
    case 0x7DF:
        canOBD2.DecodeCAN(id,data);
        break;
    default:
        if (Param::GetInt(Param::ShuntType) == 1)  ISA::DecodeCAN(id, data);
        if (Param::GetInt(Param::ShuntType) == 2)  SBOX::DecodeCAN(id, data);
        if (Param::GetInt(Param::ShuntType) == 3)  VWBOX::DecodeCAN(id, data);
        selectedInverter->DecodeCAN(id, data);
        selectedVehicle->DecodeCAN(id, data);
        selectedCharger->DecodeCAN(id, data);
        selectedChargeInt->DecodeCAN(id, data);
        selectedBMS->DecodeCAN(id, (uint8_t*)data);
        selectedDCDC->DecodeCAN(id, (uint8_t*)data);
        selectedShifter->DecodeCAN(id,data);
        selectedHeater->DecodeCAN(id, data);
        break;
    return false;
Has thanked: 330 times
Been thanked: 848 times
Re: CAN Callback - Zombieverter VCU
Correct this is the limitation, it is all legacy code and being stretched very far and is breaking at the seams.
