Hi Everyone.
I recently had an issue with my PWM signals not arriving at my gate driver pcbs. As it turned out the problem was self inflicted in that I had reversed a component. Going forward I have attached my gate drivers and I have perfect outputs on GTop and GBot but spurious looking signals on ETop and EBot. Do I ignore this or should I have similar signals on the E outputs.? Maybe somebody can clear this up for me as I don't want to mess up again.
Regards
Stephen
PWM Point of Clarification
Stephen Darbey
- Been thanked: 3 times
- Been thanked: 1918 times
Re: PWM Point of Clarification
EBot should be plain DC as it's connected to HV ground. ETop will swing at your DC voltage. Provided there is a DC voltage.
If your measure Gx vs. Ex they should look exactly the same.
