Tuning Nissan Leaf 1st generation - Map modification
kubeczek
Post by kubeczek »
Hi everyone, has anyone modified their Leaf with the features below? As far as I know, all you have to do is read the map, edit it, and re-upload it.
Power increased to 94kW
Sailing mode in D
One-pedal drive mode in B
Improved heat pump and cold battery performance
eee291
Has thanked: 13 times
Re: Tuning Nissan Leaf 1st generation - Map modification
Post by eee291 »
Not that I know of, but now you have piqued my curiosity. Do you know of someone who has done this?
ginetto
Been thanked: 9 times
Post by ginetto »
check all reaf can bridge related repos here https://github.com/dalathegreat there you have amny pieces where to do Sail Mode (I've it installed in aze0). I do not suggest to increase power other if you have a custom battery pack that allow enough discharge.
I do not know any code implementing one-pedal drive, but in any case you can do cooking cystom ce from what available in dala's repo.
No idea what do you mean writing "Improved heat pump and cold battery performance"
