Canbus extension board
Posted: Thu Apr 23, 2020 8:36 pm
For those of us who are pre canbus era, I have ruined my leaf adapater board tring to solder extra wires directly to it .
Just a idea would this tiny board work with the V3 board connected to the can bus,
could wire directly to the board, inputs and outputs
It was orignal made for motor sport, fits in the middle of the steering wheel so you connect pots, switches, LEDs.
https://rrrshop.co.uk/ecumaster-steerin ... 1116-p.asp
quick overview:
CAN BUS 2.0B
500 or 1000kbps, user selectable
different CAN ID and CAN frame structures can be selected,
only 25x25mm in size,
8 switch inputs (switched to ground)
8 analog inputs / rotary switch inputs, 0-5V, 10bits
4 low side outputs (0.5A, resistive and inductive loads)
6-22V power supply
+5V output for powering rotary switches, sensors and potentiometers
do you think this could work ??
quick overview:
CAN BUS 2.0B
6-22V power supply
