Toyota Prius Gen3 Board
Prius Gen3 Control Board v2
Prius Inverter
Control Board
As designed by Damien Maguire, the open source hardware for the control board can be purchased from his website:
Toyota Boards
Development History
Vendors
EVBMW Webshop
Support
Inverter Model Numbers
G9200-47141 Auris 2012, RHD
G9200-47230 Prius 2015 F1789-52010 Yes 154x143mm https://openinverter.org/forum/viewtopic.php?p=29248#p29248
G9200-52010 Yaris
Prius C
Extra voltage regulator on Prius Gen3 board
LDO strengthening
Motor Temperature Sensor correction.
Boards currently have an error with the temperature sensor circuit. R14 is supposed to be in parallel with C11 to form the voltage divider. One workaround would be to put a 1k resistor from one of the pads to ground. this can be done externally if you'd rather not modify the board, put a 1k ohm resistor from MG2_STATOR_T2 to a ground pin. Then connector the temperature sensor from MG2_STATOR_T1 to MG2_STATOR_T2 as normal.
Wifi Module Correction
The capacitor may need increasing to 10uF deal with noise. The table below shows which boards need updating and which capacitor(s) to update.
Board Version Cap(s) needs updating? Cap(s) to update
Single motor, large board (v1b) Maybe C48
Single motor, small board (v1c) Maybe C49
Single motor, small board (v1c, block 3) Maybe C49
Dual motor, small board (v1d) No N/A
Dual motor, large board (v1d) Maybe C58 and C86
Dual motor, large board (v1d, block 3) Maybe C58 and C86
Dual motor, large board (v1d, block 4) No N/A
Soldering The Breakout Board
Soldering the Main Board
And Conn8, again easy.
[add photo]
Powering up
Checking voltages
Check for ~3.3v here on C32
Finally the 26v
Firmware
Wifi Module Firmware
  3. Write code to ESP8266
Programming Firmware
For Windows
Atmega328p Firmware
Be super careful never to program the Atmega while high voltage is applied and caps are not discharged. When cycling through the boot loader, it seems to do something strange that will blow up the otherwise bullet proof buck/boost converter! Also be aware that Arduino also cycles through the boot loader when closing the serial terminal!
Inverter Parameters
udcofs 0 DC link 0V offset
Parameters Details
First Run (PWM verify)
Navigate to the Web Interface
Using a scope, look for a PWM signal on MG2 A/B/C Hi/Low on the 50 pin connector. R74 through R79 can be used as test points for the PWM signal - these are located next to the 50 pin connector as shown in the image below.
Partial shot of the 50 pin connector showing the location of the resistors which can be used as test points to check for the PWM signal on MG2 A/B/C Hi / Low.
Stop the inverter
DC-DC Converter
D.Maguire
#include <Metro.h>
int HVLow = 0;        // voltage on low side of converter
int HVHi = 0;        // voltage on high side of converter
int SetV = 0;       //set point voltage
int PWMDuty = 0;    //pwm duty cycle
Metro timer_pwm=Metro(5);
void setup() {
  Serial.begin(9600);//
  TCCR1B = TCCR1B & B11111000 | B00000010;    // set timer 1 divisor to  8 for PWM frequency of  3921.16 Hz
  SetV=210;  //set at 210v to run dcdc
  PWMDuty=0;
void loop() {
    HVHi = (analogRead(A1)*1.25);
    updatePWM();  //call pwm update routine.
    serialOUT();  //call serial out routine
void serialOUT()
  if(timer_serial.check()){
  Serial.print("Low Vbus = ");
  Serial.print(HVLow);
  Serial.print("Volts");
  Serial.print(HVHi);
  Serial.println(PWMDuty);
void updatePWM()
if(timer_pwm.check()){
  if(HVHi>300){  //if hv is above 300v start ramping up pwm and regulate to setpoint.
    if (HVLow<SetV) PWMDuty++;
    if (HVLow>SetV) PWMDuty--;
    if (PWMDuty<0)  PWMDuty=0;
    if (PWMDuty>250)  PWMDuty=250;
    analogWrite(10,PWMDuty);
  if(HVHi<250)
      PWMDuty--;;  //if hv is lower then 250v ramp down pwm
// I/O-PINS
* SETUP *
void setup()
* LOOP *
void loop()
And Replace
12v Battery Connection
The HV battery connection is below, DO NOT directly connect the battery here. It needs to be connected via contactors and a pre-charge resistor. This connection point by-passes the buck/boost converter.
Motor Connection
Some versions of this inverter have the U-V-W labels for the three phase wires stamped into the case and some do not. These are shown below in case you have a version of the inverter without them and need to connect to a motor other than the originial prius transaxle.
Parallel MG1 and MG2 on a single motor
IDC Connector
Connections are as follows:
Pin Number Label Description
23 MG2_STATOR_T1 5V output for the motor temperature sensor. These are typically variable resistance devices. Connect one side of the sensor here.
24 MG2_STATOR_T2 Input from motor temperature sensor. Connect the other side of the sensor here. (Note the board correction above. Do not connect if it hasn't been addressed by a new revision or work around)
28 HV_CON ?
31 EVSE_PROX
32 CONTROL_PILOT
Ampseal Socket & Plug
AMPSeal socket (male) in 3D printed surround with pins marked
22 MOTOR TEMP SENSOR T1 5V output for the motor temperature sensor. These are typically variable resistance devices. Connect one side of the sensor here.
23 MOTOR TEMP SENSOR T2 Input from motor temperature sensor. Connect the other side of the sensor here. (Note the board correction above. Do not connect if it hasn't been addressed by a new revision or work around)
27 CHARGER HV DC REQUEST
30 EVSE PROXIMITY SIGNAL
31 EVSE CONTROL PILOT SIGNAL
34 NOT USED
35 NOT USED
Connecting Resolver
Inverter as charger
Buck Mode Charging.
#define AC_PRECHARGE_MINIMUM_VOLTAGE 550  // European 3-phase rectifies to 600V, Single Phase 240v rectifies to 340V
#define PRECHARGE_BOOST_VOLTAGE 550  // European 3-phase rectifies to 600V, Single Phase 240v rectifies to 340V
3D Printed Parts
Frequently Asked Questions
Damien's Prius Gen3 v2 Github
Bill of Materials (Github)
