Toyota P410 CVT
Revision as of 09:14, 21 February 2023 by PrecisionAnalytic (talk | contribs) (→‎Applications: Added link to url)
Description
The P410 is considered a third generation e-CVT.
Model Code
3JM
Applications
  • Toyota Prius (2010-2015) - https://youtu.be/PIYNAroYEk0 (How the Prius Hybrid Drivetrain Works (Explained))
  • Toyota Plug-in Hybrid (2012-2015)
  • Toyota Prius V (2010-2017)
  • Lexus CT 200h (2011-?)
Specifications
MG1
Rated Voltage: 650V
Max Output: 42kW[1]
MAX RPM: 13500
Power Split Device (PSD)[2]
Planetary gears (4x) 23 teeth - carrier connected to transaxle input shaft and oil pump
Sun gear 30 teeth - connected to MG1
Ring gear 78 teeth - inside Drive Gear
Locked input shaft (stationary carrier) gives -2.6:1 ratio from MG1 to Drive Gear
MG2
Rated Voltage: 650V
Max Output Power: 60 KW (80 HP) (18 second rating to 150C stator temperature with 25C coolant temperature)[1]
Max Output Torque: 207 NM (153 lb-ft)[1] at ~250A[1]
Max RPM: 13500[1]
Motor Speed Reduction Gearset (MSR)[2]
Planetary gears (5x) 18 teeth - carrier connected to case/fixed.
Sun gear 22 teeth - connected to MG2
Ring gear 58 teeth - inside Drive Gear
MG2 to Drive Gear ratio 2.636:1
Final Drive Ratio[2]
Drive Gear 55 teeth - contains PSD and MSR ring gears
Counter Driven Gear 54 teeth - on same shaft as Final Drive gear
Drive Gear to Counter Driven Gear ratio 1.0815:1
Final Drive Gear 24 teeth
Differential Ring Gear (Final Driven Gear) 77 teeth
Final Drive Ratio 3.208:1
MG2 to axle output total gear ratio 8.613:1
MG1 to axle output total gear ratio with locked input shaft 8.495:1
Oil Pump
Fluid Capacity
??L of Toyota WS fluid.
Weight
202.8 lbs
MG1 Stator
MG2 Stator
MG1 Resolver and Temperature Sensor
PIN Label Descriptoin Factory Wire Color
1 (upper right) GRF EXC
2 GSN SIN
3 GCS COS
4 (upper left) GMT Temp
5 (lower right) GRG EXCG
6 GSNG SING
7 GCSG COSG
8 (lower left) GMTG Temp Ground
MG2 Resolver
PIN Label Description Factory Wire Color
1 (top) MSN SINE
2 MCS COS
3 MRF Exciter
4 MSNG SINE Ground
5 MCSG COS Ground
6 (bottom) MRFG Exciter Ground
MG2 Temperature Sensor
1 MMTG Temp Sensor Ground Black
2 MMT Temp Sensor Red
Park Shift Linkage Motor
Reference
Weber State University: 2010 - 2015 Prius Transaxle - P410 Deep Dive
https://info.ornl.gov/sites/publications/files/pub26762.pdf
Toyota Prius (XW30) Wikipedia
https://toyota-club.net/files/faq/21-12-01_faq_hybrid_tr_en.htm
