Toyota Prius Gen3 Board
Prius Inverter
Control Board
As designed by Damien Maguire, the open source hardware for the control board can be purchased from his website:
Development History
Vendors
EVBMW Webshop
Support
Inverter Model Numbers
G9200-33171 | Camry (RHD, unknown year) | ||||||
G9200-47141 | Auris 2012, RHD Prius (RHD, unknown year, Gen3) |
G9200-47162 | Prius + | F1759-47041 01 | F1789-47090 | ||||
G9200-47190 | Auris 2017 | F1759-47070 05 | F1789-52010 | ? | Forum Thread openinverter.com | ||
G9200-47210 | Prius 2012 | F1759-47070 05 | YES | 154x143mm | Yes | https://openinverter.org/forum/viewtopic.php?p=16539#p16539 | |
G9200-47220 | Prius 2014 | F1759-47070 05 | YES | 154x143mm | Yes | https://openinverter.org/forum/viewtopic.php?p=21384#p21384 | |
G9200-47230 | Prius 2015 | F1789-52010 | Yes | 154x143mm | https://openinverter.org/forum/viewtopic.php?p=29248#p29248 | ||
G9200-52010 | Yaris
Prius C |
G9200-52031 | Yaris 2016 | F1759-52010 04 | F1789-52010 | YES | YES | ||
G9201-52012 | Prius C | F1759-52010 | F1789-52010 | YES (presumably) | Forum Thread openinverter.com | ||
G9200-52030 | Prius C (a.k.a. Prius Aqua) | F1759-52010 04 | F1789-52010 | 154mm long | Forum Thread openinverter.com |
LDO strengthening
Motor Temperature Sensor correction.
Boards currently have an error with the temperature sensor circuit. R14 is supposed to be in parallel with C11 to form the voltage divider. One workaround would be to put a 1k resistor from one of the pads to ground. this can be done externally if you'd rather not modify the board, put a 1k ohm resistor from MG2_STATOR_T2 to a ground pin. Then connector the temperature sensor from MG2_STATOR_T1 to MG2_STATOR_T2 as normal.
Wifi Module Correction
The capacitor may need increasing to 10uF deal with noise. The table below shows which boards need updating and which capacitor(s) to update.
Board Version | Cap(s) needs updating? | Cap(s) to update |
Single motor, large board (v1b) | Maybe | C48 |
Single motor, small board (v1c) | Maybe | C49 |
Single motor, small board (v1c, block 3) | Maybe | C49 |
Dual motor, small board (v1d) | No | N/A |
Dual motor, large board (v1d) | Maybe | C58 and C86 |
Dual motor, large board (v1d, block 3) | Maybe | C58 and C86 |
Dual motor, large board (v1d, block 4) | No | N/A |
Soldering The Breakout Board
Soldering the Main Board
Also easiest is to start with this connector, whilst the most complicated, starting with an unpopulated board allows easier access to it as the following connectors are largely around this one.
Depending on the kit and time you received it due to chip shortages, you might have IC12 and IC14 unpopulated and need to solder them on.
Each chip's 'pin one' has a small notch to indicate it and this matches the line and IC12 /IC14 silk screen on the board.
Again these are easier to get out of the way before the connectors are positioned.
And Conn8, again easy.
Ignore the 'Notch' on the board it needs to face outwards to the edge of the board, you'll also need to turn the sensor cables 180 deg to fit when installing the board.
Powering up
Checking voltages
Check for ~3.3v here on C32
Finally the 26v
Firmware
Wifi Module Firmware
- Write code to ESP8266
- Write filesystem to ESP8266
Programming Firmware
For Windows
A wifi network should be visible with the name "inverter" connect to it with password "inverter123"
Atmega328p Firmware
Be super careful never to program the Atmega while high voltage is applied and caps are not discharged. When cycling through the boot loader, it seems to do something strange that will blow up the otherwise bullet proof buck/boost converter! Also be aware that Arduino also cycles through the boot loader when closing the serial terminal!
Inverter Parameters
Parameter | Suggested Value | Notes |
pwmfrq | 2 | PWM frequency. 0=17.6kHz, 1=8.8kHz, 2=4.4kHz, 3=2.2kHz. Needs PWM restart |
pwmpol | 0 - Active High | DO NOT PLAY WITH THIS! |
deadtime | 130 | Deadtime between highside and lowside pulse. 28=800ns, 56=1.5µs. Not always linear, consult STM32 manual. Needs PWM restart |
il1gain | 4.56 | Digits per A of current sensor L1 |
il2gain | 4.5 | Digits per A of current sensor L2 |
udcgain | 5 | Digits per V of DC link |
udcofs | 0 | DC link 0V offset |
udclim | 540 | High voltage at which the PWM is shut down |
snshs | 1 | Heatsink temperature sensor. 0=JCurve, 1=Semikron, 2=MBB600, 3=KTY81, 4=PT1000, 5=NTCK45+2k2, 6=Leaf |
pinswap | 8 | 0=None, 1=Currents12, 2=SinCos, 4=PWMOutput13, 8=PWMOutput23 |
Parameters Details
First Run (PWM verify)
Navigate to the Web Interface
Change the parameter encmode to 'AB' as at the moment we don't have any sensors connected. Set udcmin to 0 to disable precharge.
Using a scope, look for a PWM signal on MG2 A/B/C Hi/Low on the 50 pin connector. R74 through R79 can be used as test points for the PWM signal - these are located next to the 50 pin connector as shown in the image below.
Stop the inverter
DC-DC Converter
D.Maguire
#include <Metro.h>
Metro timer_pwm=Metro(5);
void setup() {
Serial.begin(9600);//
PWMDuty=0;
void loop() {
HVHi = (analogRead(A1)*1.25);
void serialOUT()
if(timer_serial.check()){
Serial.print("Low Vbus = ");
Serial.print(HVLow);
Serial.print("Volts");
Serial.print(HVHi);
Serial.println(PWMDuty);
void updatePWM()
if(timer_pwm.check()){
if (HVLow<SetV) PWMDuty++;
if (HVLow>SetV) PWMDuty--;
if (PWMDuty<0) PWMDuty=0;
if (PWMDuty>250) PWMDuty=250;
analogWrite(10,PWMDuty);
if(HVHi<250)
// I/O-PINS
* SETUP *
void setup()
* LOOP *
void loop()
And Replace
12v Battery Connection
The HV battery connection is below, DO NOT directly connect the battery here. It needs to be connected via contactors and a pre-charge resistor. This connection point by-passes the buck/boost converter.
Motor Connection
Some versions of this inverter have the U-V-W labels for the three phase wires stamped into the case and some do not. These are shown below in case you have a version of the inverter without them and need to connect to a motor other than the originial prius transaxle.
Parallel MG1 and MG2 on a single motor
IDC Connector
Connections are as follows:
Pin Number | Label | Description |
1 | 12V_IN | Provide with +12V supply from battery or power supply for testing |
2 | 12V_IN | Provide with +12V supply from battery or power supply for testing |
3 | MG2_FORW_IN | Active high signal at 12V (switches at >7V) to tell the inverter which way to spin the motor. Take positive feed from 12V battery or supply and wire through a three position switch, with the switched connections running to forward and reverse. |
4 | MG2_REVER_IN | Active high signal at 12V (switches at >7V) to tell the inverter which way to spin the motor. Take positive feed from 12V battery or supply and wire through a three position switch, with the switched connections running to forward and reverse. |
5 | MG2_START | Active high signal at 12V (switches at >7V) to start the inverter and move it from pre-charge to run mode. Typically connected to the momentary 'START' position of your ignition switch. |
6 | MG2_BRAKE_ON | Active high signal at 12V (switches at >7V) to inform the inverter that the car is under braking. Typically takes a feed from the brake switch that also turns on brake lights etc. |
7 | CRUISE_IN | Active high signal at 12V (switches at >7V) to turn on cruise control mode. This sets the current motor speed as the set point for cruise control. Cruise control is disabled by a signal from the brake switch. |
8 | VCC_5V | +5V supply for temperature and throttle sensors |
9 | MG2_ACCEL | 5V analogue input from first channel of throttle sensor. These typically take a 5V supply and ground and return to this pin a variable voltage that indicates throttle position. |
10 | MG2_BRAKE_TRANS | 5V analogue input from second channel of throttle sensor. These typically take a 5V supply and ground and return to this pin a variable voltage that indicates throttle position. |
11 | GND | Common ground for 12V supply or 5V return. |
12 | GND | Common ground for 12V supply or 5V return |
13 | CAN_EXT_H | CANBus digital communication connection for remote interface with inverter |
14 | CAN_EXT_L | CANBus digital communication connection for remote interface with inverter |
15 | VCC_5V | +5V supply for temperature and throttle sensors |
16 | MG2_ENC_1 | Can be either digital input for encoder (in which case, connect the relevant encoder output here and provide the device with 5V and ground), or one of the two connections for the SIN winding if you are using a resolver for motor position. |
17 | MG2_ENC_2 | Can be either digital input for encoder (in which case, connect the relevant encoder output here and provide the device with 5V and ground), or one of the two connections for the COS winding if you are using a resolver for motor position. |
18 | GND | Common ground for 12V supply or 5V return |
19 | MG2_COSA | Connect SIN winding of motor resolver here and to Encoder Channel A |
20 | MG2_SINA | Connect COS winding of motor resolver here and to Encoder Channel B |
21 | MG2_EXCA | Connect exciter winding of motor resolver here and to ground |
22 | GND | Common ground for 12V supply or 5V return |
23 | MG2_STATOR_T1 | 5V output for the motor temperature sensor. These are typically variable resistance devices. Connect one side of the sensor here. |
24 | MG2_STATOR_T2 | Input from motor temperature sensor. Connect the other side of the sensor here. (Note the board correction above. Do not connect if it hasn't been addressed by a new revision or work around) |
25 | MAIN_CON | Open Collector (Will switch the ground side from disconnected to ground).
26 | PRECHG_RLY | Open Collector (Will switch the ground side from disconnected to ground).
27 | AC_CON | Open Collector (Will switch the ground side from disconnected to ground).
28 | HV_CON | ? |
29 | AC_PRECH | Open Collector (Will switch the ground side from disconnected to ground).
30 | GND | Common ground for 12V supply or 5V return |
31 | EVSE_PROX | |
32 | CONTROL_PILOT | |
33 | CHG_CANH | CANBus digital communication connection for remote interface with charger |
34 | CHG_CANL | CANBus digital communication connection for remote interface with charger |
Ampseal Socket & Plug
TE connectivity 776164-1 and 776163-1 are a matched pair[3].
Pin Number | AMPSeal Pinout Label | Description |
1 | 12V SUPPLY POSITIVE | Provide with +12V supply from battery or power supply for testing |
2 | GROUND | Common ground for 12V supply or 5V return |
3 | FORWARD DIRECTION SIGNAL | Active high signal at 12V (switches at >7V) to tell the inverter which way to spin the motor. Take positive feed from 12V battery or supply and wire through a three position switch, with the switched connections running to forward and reverse. |
4 | REVERSE DIRECTION SIGNAL | Active high signal at 12V (switches at >7V) to tell the inverter which way to spin the motor. Take positive feed from 12V battery or supply and wire through a three position switch, with the switched connections running to forward and reverse. |
5 | START SIGNAL | Active high signal at 12V (switches at >7V) to start the inverter and move it from pre-charge to run mode. Typically connected to the momentary 'START' position of your ignition switch. |
6 | BRAKE DIGITAL SIGNAL | Active high signal at 12V (switches at >7V) to inform the inverter that the car is under braking. Typically takes a feed from the brake switch that also turns on brake lights etc. |
7 | CRUISE CONTROL SIGNAL | Active high signal at 12V (switches at >7V) to turn on cruise control mode. This sets the current motor speed as the set point for cruise control. Cruise control is disabled by a signal from the brake switch. |
8 | 5V OUT | +5V supply for temperature and throttle sensors |
9 | ACCELERATOR CHAN 1 INPUT | 5V analogue input from first channel of throttle sensor. These typically take a 5V supply and ground and return to this pin a variable voltage that indicates throttle position. |
10 | ACCELERATOR CHAN 2 INPUT | 5V analogue input from second channel of throttle sensor. These typically take a 5V supply and ground and return to this pin a variable voltage that indicates throttle position. |
11 | GROUND | Common ground for 12V supply or 5V return. |
12 | INVERTER CAN HIGH | CANBus digital communication connection for remote interface with inverter |
13 | INVERTER CAN LOW | CANBus digital communication connection for remote interface with inverter |
14 | +5V OUT | +5V supply for temperature and throttle sensors |
15 | ENCODER CHAN A | Can be either digital input for encoder (in which case, connect the relevant encoder output here and provide the device with 5V and ground), or one of the two connections for the SIN winding if you are using a resolver for motor position. |
16 | ENCODER CHAN B | Can be either digital input for encoder (in which case, connect the relevant encoder output here and provide the device with 5V and ground), or one of the two connections for the COS winding if you are using a resolver for motor position. |
17 | GROUND | Common ground for 12V supply or 5V return |
18 | RESOLVER SIN | Connect SIN winding of motor resolver here and to Encoder Channel A |
19 | RESOLVER COS | Connect COS winding of motor resolver here and to Encoder Channel B |
20 | RESOLVER EXC | Connect exciter winding of motor resolver here and to ground |
21 | GROUND | Common ground for 12V supply or 5V return |
22 | MOTOR TEMP SENSOR T1 | 5V output for the motor temperature sensor. These are typically variable resistance devices. Connect one side of the sensor here. |
23 | MOTOR TEMP SENSOR T2 | Input from motor temperature sensor. Connect the other side of the sensor here. (Note the board correction above. Do not connect if it hasn't been addressed by a new revision or work around) |
24 | MAIN HV CONTACTOR | Open Collector (Will switch the ground side from disconnected to ground).
25 | HV PRECHARGE RELAY | Open Collector (Will switch the ground side from disconnected to ground).
26 | CHARGER AC INPUT RELAY | Open Collector (Will switch the ground side from disconnected to ground).
27 | CHARGER HV DC REQUEST | |
28 | CHARGER AC PRECHARGE RELAY | Open Collector (Will switch the ground side from disconnected to ground).
29 | GROUND | Common ground for 12V supply or 5V return |
30 | EVSE PROXIMITY SIGNAL | |
31 | EVSE CONTROL PILOT SIGNAL | |
32 | CHARGER CAN HIGH | CANBus digital communication connection for remote interface with charger |
33 | CHARGER CAN LOW | CANBus digital communication connection for remote interface with charger |
34 | NOT USED | |
35 | NOT USED |
Connecting Resolver
Inverter as charger
Buck Mode Charging.
3D Printed Parts
More information on these parts, such as where to install them and how they fit together, can be found in this forum post https://openinverter.org/forum/viewtopic.php?t=836
Frequently Asked Questions
Bill of Materials (Github)
