ZombieVerter VCU
Revision as of 20:05, 31 January 2025 by Bratitude (talk | contribs) (clean up zombie page-work in progress)
latest stable software release: https://github.com/damienmaguire/Stm32-vcu/releases.
Support is available via this section on the forum
There is a growing supply of OEM inverters, chargers, dc/dc converters, heaters, etc, requiring some control method in order to use them in a EV conversion. Instead of replacing the original logic board in these devices (with some devices it is physically impossible to do so), a vehicle control unit (vcu) which talks in its native communication protocol is a much more elegant solution. With a vcu, we can simply tell these logic boards what we want in a language they can understand, and they will do it. As far as they are concerned, they are still installed in the OEM vehicle they left the factory in.
What is not elegant is having a series of bespoke vcu boards for each device. Instead, a master vcu which can handle a variety of different communication protocols(thus a variety of devices) was born; the zombiVerter !
The zombieVerter is available via evbmw's web shop
Based around the original design of the open inverter platform, the zombieVerter consists of 2 main parts:
  • a web interface
  • a communication protocol
With onboard wifi, you can access the web interface (http://192.168.4.1/) to:
  • set up/calibrate the different devices(inverter, charger, etc) connected to the vcu.
  • tune control parameters (throttle, regen, charge speed, charge time, BMS limits, etc)
  • log info
  • graph and plot live data (rpm, amps, charge rate, etc)
  • update firmware
there are many different methods OEM devices communicate, all which the zombieVerter can speak!
  • pwm
  • canbus
  • linbus
  • sync serial
  • etc
Zombiverter features:
  • Throttle mapping
  • Precharge + contactor control
  • coolant pump control
  • charger control
  • charge port spoofing
  • inverter control
  • Temp based derating
  • BMS limits
  • forwarded/reverse input
  • heater controller
  • Cruise control
    • traction control*
  • Fuel gauge driver
  • tach gauge driver
  • OBD-II interface
  • charge timer
  • Firmware updates via the web interface
  • Graphing and monitoring
  • etc
Enclosure and header
Looking to build a zombiverter VCU your self or your kit comes with missing hardware? see the Zombiverter hardware page for build instructions
The enclosure kit:
options:
  1. blank connector 211PC562S8009
  2. prewired with 3m long leads. 211PC562S0008
The original connectors are from aptiv (delphi), where you can find drawings and 3d models:
aliexpress/alibaba knock-offs:
  • Enclosure Kit with Header, connector and pins[1]
  • Connector and pins[2]
  • Prewired connector with 3M leads (limited colors which will not match standard wire coloring conventions)[3]
Isabellenhütte Heusler
wiring
Pin Out Diagrams
VCU pinout diagram
GS450H with zombieverter
List of connections to system components (GS450 application)
Leaf stack with zombiverter
leaf stack to zombie
Tesla SDU with Zombieverter
Zombieverter Can Bus Control of SDU
Notes:
  • This drawing is intended to show the minimum components and connections needed for Zombieverter control of an OI SDU via Can bus.  Adapting power and Can bus connections for other OI inverters should function in the same manner, but this needs verification.
  • All power connections must be fuse protected.  Fuses are not shown for simplification.
  • The following observations were made using Zombieverter firmware 2.20A and SDU firmware 5.35R:
  1. The Zombieverter does not enable inverter power prior to entering PreCharge mode.  An external device other than the inverter is required to supply the udc measurement for switch to Run mode.  This function is supported by the shunt and BMS options available in the Zombieverter parameters.
  2. A third device must be on the Can bus with the Zombieverter and Inverter.
  3. Requirements 1. and 2. are satisfied in the drawing by the IVT shunt.
  4. All devices except the Zombieverter are shown as powered by the ignition switch.  Some devices may need to move to permanent 12V supply to support other functions, such as charging.
  5. An inverter power relay is required for Zombieverter control.
  6. Can mapping to pass data and commands from the Zombieverter to the inverter is hard coded in the firmware for both devices.  Manual mapping is required for the inverter to transmit data to the Zombieverter.  The Zombieverter is hard coded to receive this data.  The following values need to be manually mapped in the inverter. Note: mapping uses hex address values, multipliers may need to change to provide correct values (confirm in Zombieverter spot values), inverter udc gets mapped to inv udc in the Zombieverter.
Spot Value Hex Address Offset # Bits Multiplier Map
speed 400 0 16 1 Tx
tmphs 410 0 16 10 Tx
udc 420 0 16 10 Tx
opmode 430 0 8 1 Tx
Initial start-up and testing
Wifi Setup
Configuration Setup
  • Apply the Ignition T15 in 12V signal. The relay supplying 12V to the inverter should now be on.
  • Check the accelerator by applying it gradually and watching / refreshing the interface. You should see values at pot change as the pedal is pressed. potmin should be set just above where your off-throttle position is, and potmax just below the value seen at maximum travel [note this is the opposite for versions 1.06A to 1.11A ). Same for pot2min and pot2max, if they are electrically connected. The resulting value as a 0-100 value can be seen at potnom.
  • Once the contactors are on, select forwards direction. For example if dirmode is set to "Switch" then a 12V signal applied to the Forward input will work.
  • Carefully apply the accelerator and the motor should begin to turn. Do not spin the motor up to any speed if you are using a test power supply.
    • Note: Leaf inverter requires minimum of 180v to operate, it is also sensible to test with rev limit set to 1000 RPM.
leaf stack with zombiverter
Software
GD variant:
Status as of November 20 2021
UPDATE November 23 2021
68 - // adc_start_conversion_regular(ADC1); // Comment out for GD MCUIn the file "stm32_can.cpp" @ starting at line 305 modify as follows :
That recursively pulls in copies of libopeninv, etc and tracks them...   Hence your file-path should look like
./Stm32-vcu/libopeninv/src/
Software update
Initializing an ISA Shunt
Under Comms in the web interface, there is now an ISAMode option. By default its in "Normal" (Off on Rev 2). If you want to initialize a new shunt, connect it up, power on the shunt and vcu, select "Init" (On on Rev 2), hit save parameters to flash. Power cycle the vcu and shunt at same time (they should be on same 12v feed anyway). The shunt will initialize. Select ISAMode "normal" (Off on Rev 2), save to flash again and reboot again. The shunt should now be up and running. If the shunt doesn't initialise correctly, separate the shunt and VCU supplies and power cycle the VCU two or three seconds after the shunt power is cycled. This has fixed an initialise issue for a number of ISA shunts and possibly requires a VCU code fix that delays the initialising for a few seconds to allow the shunt to power up.
Low side Outputs.
  • GP Out 3
  • GP Out 2
  • TransSL2- (If not using the GS450H)
High side PWM.
  • PWM 3
  • PWM 2
  • PWM 1
Ground Input pins
PB1
PB2
PB3
Pin functions:
  • ChaDemoAIw - OUTPUT - used as part of the Chademo charging protocol for the charge allow output to the charger.
  • OBCEnable - OUTPUT: activates as part of the ExtCharger module
  • HeaterEnable - OUTPUT: activates only in run mode and when coolant pump is on
  • RunIndication - OUTPUT: activates when zombie is in run mode
  • WarnIndication - OUTPUT
  • CoolantPump - OUTPUT: activates during precharge, usually used for coolant pumps
  • NegContactor - OUTPUT: activates during precharge for negative contactor
  • BrakeLight - OUTPUT: activates when brake input is detected
  • ReverseLight - OUTPUT: activates when direction is reverse
  • BrakeVacPump DIGITAL OUTPUT: when BrakeVacSensor below threshold this is turned on.
  • HeatReq - DIGITAL INPUT
  • HVRequest - DIGITAL INPUT - when used with ext charger setting will start precharge cycle and put VCU into charge mode.
  • ProxPilot - ANALOGUE INPUT - detect a charging cable plug in, requires external resistors, values depend on type 1 or type 2
  • BrakeVacSensor - ANALOGUE INPUT - read a vacuum sensor and turn on the BrakeVacPump DIGITAL OUTPUT
  • CoolingFan - OUTPUT: activates when FanTemp setpoint is reached
  • HVActive - OUTPUT: activates when contactors are closed and VCU is in run or charge mode
  • PWMTim3 -
  • CpSpoof - PWM OUTPUT: used to spoof CP signal to OBC if also using a charging interface such as FOCCCI or I3LIM
  • GS450Hpump - PWM OUTPUT: used to run GS450H oil pump
Proximity Pilot
Firmware
Troubleshooting
Serial Connection
If your ZV fails on the update and the Web User Interface is reporting "firmware: null" it's possibleyou'll need to reflash the firmware, bootloader via an STLink and/or delete any existing .bin and .Json files from the files section.
  1. Firstly, download the bootloader and latest zombieverter firmware from here [4] and here [5] as .hex files, this ensures you don't need to know the address of the file and avoids user error when flashing via STLink (I used a cheap STLink v2 clone without issue but it seems there is a mix of experiences with them).
  2. Download STMCubeProgrammer (other STM flashing softwares are available but the following instructions are based on what has worked for me).
  3. Upgrade the firmware on your STLink dongle using STMCubeProgrammer (I'm not sure if this is 100% necessary but seems prudent).
  4. Connect the Clock (SWclk), Gnd and Data (SWDio) of your STLink to the Zombieverter test points (near to the STM32 chip, they are labelled C, G, D) as well as 12V and Gnd to the Zombieverter main power pins and ensure your STMCubeprogrammer is able to connect to it, I also disconnected the wifi board just incase.
  5. Perform a "full chip erase", then reflash the latest bootloader and firmware hex files.
  6. Remove your STLink from the zombieverter, connect the wifi board and check connectivity.
  7. Begin Zombieverter-ing.
