Toyota Prius Gen3 Board
Prius Gen3 Control Board v2
Prius Inverter
Control Board
Prius Gen3 Partial
Development History
Vendors
- ?? List of known vendors with support?
Support
Inverter Model Numbers
G9200-47141 Auris 2012, RHD
G9200-47140 Prius 2010 F1759-47041 01
G9200-47190 Auris F1759-52010 04 ? Forum Thread openinverter.com
G9200-52010 Yaris F1759-52010 04 F1789-52010 154x143mm https://openinverter.org/forum/viewtopic.php?f=14&t=257&p=5828#p5828
Soldering The Breakout Board
I started with the breakout board. Soldering the Ampseal connector the the board, the board instructs which side to fit it.
Next flip it over and put the lock connector on, notch upwards, the version of the board I have is marked incorrectly with the notch at the bottom.
Soldering the Main Board
The main board is mostly pretty easy to solder, the one exception is the 50 way white connector.
[Add Image]
And Conn8, again easy.
[add photo]
Powering up
Checking voltages
Check for ~3.3v here on C32
Finally the 36v
Firmware
Wifi Module Firmware
Main Firmware
For Windows
Atmega328p Firmware
DC-DC Converter
12v Battery Connection
[Add details]
[Add battery connection details]
Damien's Prius Gen3 v2 Github
