Toyota Prius Gen3 Board
Prius Inverter
Control Board
Development History
Vendors
Support
Inverter Model Numbers
G9200-47140 | Prius 2010 | F1759-47041 01 | |||||
G9200-47190 | Auris | F1759-52010 04 | ? | Forum Thread openinverter.com | |||
G9200-52010 | Yaris | F1759-52010 04 | F1789-52010 | 154x143mm | https://openinverter.org/forum/viewtopic.php?f=14&t=257&p=5828#p5828 | ||
G9201-52012 | Prius C | F1759-52010 | F1789-52010 | YES (presumably) | Forum Thread openinverter.com |
[Insert Photo]
Soldering The Breakout Board
Soldering the Main Board
And Conn8, again easy.
[add photo]
Powering up
Checking voltages
Check for ~3.3v here on C32
Finally the 26v
Firmware
Wifi Module Firmware
Main Firmware
For Windows
Atmega328p Firmware
DC-DC Converter
12v Battery Connection
[Add details]
[Add battery connection details]
Ampseal Socket & Plug
There are two part numbers for the large 35 way Ampseal through hole socket
TE Connectivity 1-776163-1 (black) or 1-776163-4 (grey)
There are numerous part numbers for the mating Free Hanging Plug Housing, the most common and affordable is:
TE Connectivity 776164-2
Connecting Resolver
