Toyota Prius Gen2 Board
- Large part availability, Prii have been made in large numbers for 20 years and spares are inexpensive.
Pin # | Designation | Description | Wire Color
Wire Color
(Harness Side) |
1 | vacant | |||
2 | GIVA | MG1 Phase Current V | LightGreen | White |
3 | GIVB | MG1 Phase Current V | Purple-Red | Black |
4 | GUU | MG1 PWM U - Speed Signal Wave | Blue | Black |
5 | GVU | MG1 PWM V - Speed Signal Wave | Blue-Red | Green |
6 | GWU | MG1 PWM W - Speed Signal Wave | Yellow | Yellow |
7 | MIVA | MG2 Phase Current V | LIghtGreen-Black | Green |
8 | MIVB | MG2 Phase Current V | Purple-Yellow | White |
9 | MUU | MG2 PWM U - Speed Signal Wave | Blue-Black | Black |
10 | MVU | MG2 PWM V - Speed SIgnal Wave | Blue-Yellow | White |
11 | MWU | MG2 PWM W - Speed Signal Wave | Yellow-Black | Red |
12 | VH | Inverter Capacitor Voltage | Purple | Yellow |
13 | CPWM | Boost converter PWM switch signal | Blue | Black |
14 | CT | Boost converter temperature sensor | Green-Red | Red |
15 | VL | Boost converter input voltage | Purple-White | Yellow |
16 | GINV | Inverter Ground | Black-White | Yellow |
17 | vacant | |||
18 | GIWA | MG1 Phase Current W | Grey | Red |
19 | GIWB | MG1 Phase Current W | Grey-Black | Green |
20 | GSDN | MG1 Shutdown | Brown-Black | Red |
21 | GIVT | MG1 Inverter Temperature | Green-Black | White |
22 | GFIV | MG1 Inverter Fail | White-Grey | Grey |
23 | MIWA | MG2 Phase Current W | Grey-Green | Red |
24 | MIWB | MG2 Phase Current W | Grey-Red | Black |
25 | MSDN | MG2 Shutdown | Brown | Green |
26 | MIVT | MG2 Inverter Temperature | Green | Light Blue |
27 | MFIV | MG2 Inverter Fail | White | Green |
28 | OVH | Overvoltage | Pink | Brown |
29 | CSDN | Boost converter shutdown signal | Brown-White | White |
30 | FCV | Boost converter fail signal | White-REd | White |
31 | OVL | Boost converter over voltage signal | Pink-Blue | Black |
32 | GCNV | Boost converter ground | Black-Red | Green |
DC-DC Converter
1 | IGCT | 12v+ | Blue |
2 | ID1 | Not Needed | Purple |
3 | S | B+ (opt) | White |
4 | NODD | 0-5v+ | Ppl/Gld |
5 | VLO | Not Needed | Blue |
6 | Vacant |
Inverter Cooling
Through Hole Control Board
How To Use
Wire Connections
Control Board Pin mapping:
TB1-1 | 12v-in | Primary 12v supply from ignition on |
TB1-2 | GND | Primary ground connection to 12v negative. All grounds are common |
TB1-3 | 5v VCC | 5V supply from board for use with throttle pot or hall pedal |
TB1-4 | Throttle In | 0-5v variable voltage input from throttle pedal or pot |
TB1-5 | Regen In | 0-5v variable voltage input. Can be used as second throttle channel or control regen from a brake pressure sensor |
TB1-6 | GND | |
TB1-7 | Brake In | 12v digital input from brake light switch. |
TB1-8 | Start In | 12v digital input from "Start" position on a traditional ignition switch. Momentary action push button can be used. |
TB1-9 | For In | 12v digital input commands motor to run in forward direction |
TB1-10 | Rev In | 12v digital input commands motor to run in reverse direction |
TB3-1 | +12v VCC | 12v output to inverter IGCT terminal (Not on the 32-pin connector, the red wire on the 2-pin connector next to it). |
TB3-2 | GND | Common ground, but used to connect to inverter GND terminal (Not on the 32-pin connector, the black wire on 2-pin connector next to it). |
TB3-3 | Phase U |
TB3-4 | Phase Y | Phase V output. Connect to Inverter MVU terminal for MG2 inverter drive or GVU for MG1 inverter drive |
TB3-5 | Phase W | Phase W output. Connect to Inverter MWU terminal for MG2 inverter drive or GWU for MG1 inverter drive |
TB3-6 | Current U | Phase currents from inverter. Requires external divider circuit. Not required to run motor or inverter. |
TB3-7 | Current Y | Phase currents from inverter. Requires external divider circuit. Not required to run motor or inverter. |
TB3-8 | MG2 Enable | Connect to Inverter MSDN to run MG2 inverter or GSDN to run MG1 inverter |
TB3-9 | MG2 Fault | Connect to MFIV for MG2 or GFIV for MG1 |
TB3-10 | DC Bus | Connect to inverter VH to measure DC link voltage |
TB2-1 | +5V VCC | 5v output to encoder for induction motor |
TB2-2 | ENCA In | Encoder input A |
TB2-3 | ENCB In | Encoder input B |
TB2-4 | GND | Encoder ground |
TB2-5 | HS Temp | Heatsink temp sensor input |
TB2-6 | MOT Temp | Motor temp sensor input |
TB4-1 | GND | Common ground |
TB4-2 | Main Con | Main HV contactor control low side switch |
TB4-3 | Precharge | HV precharge contactor control low side switch |
TB4-4 | +12 V VCC | Spare 12v output |
TB4-5 | CAN L | Can bus low signal |
TB4-6 | CAN H | Can bus high signal |
New SMD control board with enclosure and designated pinouts
Please add pictures and description.
Pin Mapping - Note : Smaller 12-pin socket is the interface to the inverter & 20-pin to the motor
20 - Pin socket
Pin#01 - ENC_B/S3
Pin#02 - S1S4
Pin#03 - ENC_A/S2
Pin#04 - R1
Pin#05 - R2
Pin#06 - 5V
Pin#07 - THROTTLE 1
Pin#08 - THROTTLE 2
Pin#09 - START_IN (12V)
Pin#10 - BRAKE_IN (12V)
Pin#11 - FORWARD_IN (12V) (1, 2 or 3 way switch)
Pin#12 - REVERSE_IN (12V) (1, 2 or 3 way switch)
Pin#13 - Motor Temp -
Pin#14 - Motor Temp +
Pin#15 - DC (HV) Switch Control (Ground signal)
Pin#16 - Pre-ChARGE Control (Ground signal)
Pin#17 - CAN L
Pin#18 - CAN H
Pin#19 - Ground
Pin#20 - 12V "Ignition"
12 - Pin socket ( starts at pin number #21) - Corresponding pin on Main White 32 pin Inverter connector is in brackets.
Pin#21 - GIVA (2)
Pin#22 - MIVA (7)
Pin#23 - GIWA (18)
Pin#24 - MIWA (23)
Pin#25 - VH (12)
Pin#26 - MIVT (26)
Pin#27 - MFIV (27)
Pin#28 - MUU (9)
Pin#29 - MVU (10)
Pin#30 - MWU (11)
Pin#31 - CPWM (13)
Pin#32 - GINV/GCNV (16/32)
Connect MSDN Pin#25 in inverter (not 25 on controller) permanently to 12V to enable the MG2 Inverter (can be tied to same 12v source as "I9")
Connect CPWM to 12V via a 470 Ohm resistor for charge mode.
Connect the 2-pole white power connector ("I9") inside inverter to 12V and Ground to power up inverter electronics.
Make sure to connect Pin #32 and GINV/GCNV to vehicle ground.
Initial Set up
Step 1 : Solder relevant (and included) connector pins to the Adapter Board
Step 2 : Plug in Wifi Adapter and connect ONLY Pin#19 - GROUND and Pin#20 - 12 Volts power supply
Confirm PWR LED lights up along with WIFI LED. Confirm ALIVE LED flashes.
Step 3 : Connect computer/laptop to the wifi network (Example - Inverter 7)
Step 4 : Go to browser toolbar and type in 192.168.4.1 + Enter. (allow pop ups/Trusted site). Confirm Web based Interface appears and list of parameters appear.
If parameters appear, you are now connected to the Adapter board and the Web based Interface - Congratulations - You are now in the Matrix !
Step 5 : Wire up 12 Pin SMD board connector to corresponding 32 Pin Inverter connector, permanent 12 volt supply to Pin #25 (MSDN) of Inverter, and 12V and Ground to 2-pole Inverter connector (next to main 32 pin white connector)
Step 6 : Connect fused 12 volt and Ground to HV Inputs (battery), along with 55 watt light bulb in series (resistor) on the Positive line
Step 7 : Connect fused 12 volt power supply for SMD board , Pin #25, and Inverter 2-pole connector - You are now set up for basic Open Loop motor spinning!
Step 8 : Connect 21 watt light bulbs in Delta connection to the 3 PWM outputs in Inverter (no motor) - https://openinverter.org/forum/download/file.php?id=4273&mode=view
Step 9 : Web Interface Basic parameters set up - to confirm PWM outputs : Full boost with 12v supply, default forward, ampnom @ 70%, and fslipspnt @1 Hz. Select - "Start Inverter in Manual Mode" Confirm flashing lights.
Step 10 : Connect motor phase wires to inverter PWM outputs. Repeat Step 9 and change "fslipspnt" by 1 unit at a time, until motor spins smoothly. (I noticed Light bulb resistor on HV line lights up when no spinning) along with high current values. Once you have the motor spinning, continue to increase the "fslipspnt" value whilst monitoring the current (ampmeter on PWM output wire) You will also notice the light bulb starting to fade untill there is no more light. Optimal motor spinning in Open Loop Mode ! (these values are related to a 12 volt HV supply - re using these parameters is still to be verified at greater supply voltages)
Software
The Control Board runs Open Inverter software. A set of known-good default inverter parameters can be found here: https://openinverter.org/wiki/Configuration_Files#Toyota_Prius_Gen2_Inverter
Do NOT program a deadtime value for the Gen2 inverter. It only uses 1 PWM per phase and the inverter itself generates a low-side and high-side signal WITH deadtime.
Charging
Relevant Parameters
Charge mode:Buck
Chargecur: 1.5
Chargekp 20
Chargeki: 10
Chargeflt 2 dig
Relevant Pins
- CSDN (pin 29 on inverter)
- Controls DC relay switch.
Physical setup
Process
