Toyota P410 CVT
Revision as of 00:38, 22 December 2021 by Lsh3rd (talk | contribs) (Add new page for Toyota P410 transaxle.)
Description
The P410 is considered a third generation e-CVT.
Applications
  • Toyota Prius (2010-2015)
  • Toyota Plug-in Hybrid (2012-2015)
  • Toyota Prius V (2010-2017)
  • Lexus CT 200h (2011-?)
Specifications
MG1
Rated Voltage: 650V
Max Output: ?
MAX RPM: 13500
Power split device planetary gearset ratio is 3.6:1.
MG2
Rated Voltage: 650V
Max Output Power: 80 HP (60 KW)
Max Output Torque: 207 NM (153 lb ft)
Max RPM:
Motor is sent through "motor speed reduction" gearset with a ratio of 2.636:1.
Final Drive Ratio
Oil Pump
Fluid Capacity
??L of Toyota WS fluid.
Weight
202.8 lbs
MG1 Stator
MG2 Stator
MG1 Resolver
MG2 Resolver
Park Shift Linkage Motor
Reference
Weber State University: 2010 - 2015 Prius Transaxle - P410 Deep Dive
Toyota Prius (XW30) Wikipedia
