Nissan Leaf Motors
Revision as of 09:22, 8 February 2023 by Scrappyjoe (talk | contribs) (Fix bullet list)
The Nissan EM motor is an electrical motor series manufactured by Nissan Motors.
It is used in a variety of vehicles, mainly the Nissan Leaf.
They are 3-phase AC synchronous power electric motors, utilizing interior neodymium permanent magnets.
Significant Community Projects
There have been a number of open source community projects based on the Nissan Leaf. These are listed, with links and proper attribution, in this section.
  • BRAT INDUSTRIES has motor couplers and adapter plates available here https://bratindustries.net/ and has opensourced an adapter plate for the EM57 motor, which can be found here.
EM61
EM61 Dimensions
em61 motor tear down
The EM61 made its debut in 2010. It was used only in the first generation Nissan Leaf (ZE0 2010-2012). It is a stand alone IPMSM motor, with a theoretical peak power output of a 250kw+.
Regarded as Nissan’s ‘R&D’ motor, due to the presence of stronger rare earth magnets. This results in a slightly higher torque output efficiency than the second generation EM57 motor.
In the stock OEM leaf, the motor was battery and inverter limited to 80kw and made 280Nm of peak torque.
EM57
em57 motor
This link leads to maintenance document for resolver wiring:
https://openinverter.org/forum/viewtopic.php?p=47467#p47467
The EM57 utilizes a stacking architecture for the power electrons, compared to the isolated nature of the EM61 motor. Whereas the inverter and motor of the EM61 were separate units connected by cables, the EM57 is an integrated package that is bolted together.
Nissan has continued to use the EM57 motor through multiple generation of vehicles, resulting in mechanically plug and play OEM inverter upgrades.
Inverters currently compatible with the EM57 motor:
  • gen 2 leaf 80kw inverter
  • gen 3 leaf 110kw inverter
  • gen 3 leaf 160kw inverter
  • Nissan Leaf (AZE0 2013-2017)
  • Nissan e-NV200 (2014-Present)
  • Nissan Leaf (ZE1 40kWh, 2018-Present)
  • Nissan Leaf (ZE1 62kWh, 2019-Present)
  • Nissan Note e-Power (2017-Present)
  • Nissan Serena e-Power (2018-Present)
EM57 Dimensions
The below photographs show the rough dimensions of the EM57. These photos were taken from https://www.diyelectriccar.com/threads/nissan-leaf-cad-files.203894/#post-1064439, which has more detailed information.
Plugs and connectors
The resolver plug is Yazaki 7283-8855-30 (https://www.auto-click.co.uk/7283-8855-30?search=7283-8855-30)
EM47
The EM47 motor released in 2020 with the refreshed Nissan Note. It is only used in Nissan's e-POWER lineup. It features a 40% size reduction and 30% weight reduction
  • Nissan Note e-Power (2020-Present)
