Leaf stack with zombiverter
Revision as of 05:32, 24 October 2023 by Bratitude (talk | contribs)
setting up a leaf stack with the zombiverter VCU
the full leaf stack ( motor/inverter, pdm (charger, dcdc, hvjb)) can be controlled with the zombieverter VCU
all you need is 12v and CANbus
wiring
wiring the zombiverter to the leaf harness
em57 resolver pinout
the motor/inverter and PDM each use there own canbus
wire canbus1 to the motor/inverter
wire canbus2 to the pdm
leaf inverter connector pinout
then select them accordingly in the zombiverter web interface
pinout of the pdm
