ZombieVerter VCU
- Development thread
- github repo
- fully built VCU boards
- partially-built VCU boards
Modern EV conversion projects often look to reuse salvaged parts from OEM vehicles, such as the motors, batteries and chargers.
The issue is that each part, and manufacture, use different methods of control and communication. Even when the methods of control are decoded, you are left with having to develop some sort of VCU to run the devices. These devices often talk different "languages", such as CANBUS, LINBUS, sync serial, PWM, etc
introducing: the "Zombieverter" VCU
a general purpose EV conversion VCU.
With a large array of inputs/outputs, control logic, and a web interface for configuration and data logging. The Zombieverter is a powerful, flexible and customizable VCU well suited for EV conversions. its also an open source project!
The Zombieverter supports popular salvaged EV parts such as:
- Nissan leaf motor, PDM/OBC, and batteries
- Mitsubishi outlander hybrid rear drive unit, and OBC (on board charger)
- Lexus gs450H and gs300H hybrid gearbox's
- chademo and ccs fast charging
- and more!
The Zombieverter features the following:
hardware:
- on board WIFI
- 3x High side PWM drivers
- 5x low side outputs
- 3x CANbus interfaces
- Linbus
- sync serial interface
- OBD-II interface
- etc
Software:
- web based user interface
- contactor control
- charger control
- charge timer
- motor(inverter) control
- heater control
- water pump control
- coolant fan control
- throttle mapping
- motor regen
- cruise control(?)
- BMS limits
- IVT shunt initialization
- data logging and graphing
- etc
- Chademo dc fast charging
- BMW E9x CAN support
- Mid-2000s VAG CAN support
- subaru CAN support
- EVS-Charge Port Controller
- VAG/VW cabin heater via lin
- and more
Assembling the VCU
Looking to build a Zombieverter VCU your self or the kit is missing hardware?
The enclosure kit options:
- aptive 56pin connector
- aptive 56pin header
<iframe width="560" height="315" src="https://www.youtube.com/embed/geZuIbGHh30?si=iQezHNJ6QfhJXdXQ" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
Wiring
each device requires different wiring setups, settings and power requirements.
wiring the zombieverter with:
Power wiring:
The zombieverter requires a permanent 12v connection. This is so that it can mange charging, timers, and monitor systems when the car is at rest. The average draw at idle is 150 mA
- pin 55 to 12v- ground
- pin 56 to 12v+ positive
the zombieverter controls power/ "ignition" signals to other devices (inverters, chargers, and dcdc converters) when required. This is done by triggering a external 12v relay. Low-side switching, meaning that it pulls to ground.
- pin 32 to ground pin on a 12v relay
- relay positive pin to 12v+
on the switch side of the realy connect one pin to 12v+ and the other to the enable pin on the device your trying to control.
such as:
- Leaf inverter enable pin
- Leaf PDM enable pin
- Mitsubisihi OBC enable pin
Contactor wiring:
the zombieveter manages the Negative, Positive and PreCharge contactors in a ev conversion. This is done based off a series of voltage measurements (UDC), which can be supplied from a variety of sources:
- ISA IVT shunt
- nissan leaf inverter
- bmw SBOX
with out a proper UDC measurement, the zombieverter will fail precharge and never go into run mode.
The contactor control pins on the zombieverter are low-side switching, meaning that they pull to ground.
The positive leads from the contactors need to be connected to 12v+ and the ground leads to:
- pin 31 for the negative contactor
- pin 33 for the positive contactor
- pin 34 for the pre-charge contactor
Throttle pedal wiring:
The zombieverter supports dual-channel throttle, this redundancy is for safety incase one channel fails or drops out. its highly recommended to use dual channel throttle. single channel is an option.
connect the following to the zombieverter pins:
- pin 45 to throttle grounds
- pin 46 to throttle channel 2
- pin 47 to throttle channel 1
- pin 48 to throttle positives
Start, Run, and Direction wiring:
The zombieverter requires 2 inputs to get into "drive" mode. These pins need to be pulled high (connected to 12v +)
- pin 15 to "on" switched input (key switched to "on")
- pin 52 to "start" momentary input (momentary key switched "ignition")
Forward and Reverse:
- pin 53 reverse
- pin 54 forward
Input/output pins:
The Zombieverter has a number of selectable input/output pins that can be used for a number of functions. These pins are:
Low side Outputs.
- GP Out 3
- GP Out 2
High side PWM.
- PWM 3
- PWM 2
- PWM 1
These are high side 12v outputs, usually for controlling gauges or auxiliary items than need a pwm signals.
Ground Input pins
PB1
PB2
PB3
Pin functions:
- ChaDemoAIw - OUTPUT - activates when Chademo charger handshake initiates
- HeaterEnable - OUTPUT: activates only in run mode and when coolant pump is on*
- WarnIndication - OUTPUT: activates when a error occurs with the zombieverter
- NegContactor - OUTPUT: activates when the negative contactor needs to be closed. ie precharge, run, charge mode, etc
- BrakeLight - OUTPUT: activates when a set brake light on threshold value is met
- ReverseLight - OUTPUT: activates when reverse direction is selected
- BrakeVacPump DIGITAL OUTPUT: activates when BrakeVacSensor threshold value is met
- CpSpoof - PWM OUTPUT: used to spoof CP signal to OBC when using a charging interface such as FOCCCI or I3LIM
- HeatReq - DIGITAL INPUT
- HVRequest - DIGITAL INPUT - starts precharge cycle and puts VCU into charge mode
- ProxPilot - ANALOGUE INPUT - detects when charge cable is plugged in
- BrakeVacSensor - ANALOGUE INPUT - vacuum sensor input, use for triggering BrakeVacPump DIGITAL OUTPUT
- PWMTim3 -
Proximity Pilot
Initial start-up and testing
once the
Configuration Setup
Software
for programming a blank board see: zombiverter programing
web interface:
Initializing an ISA Shunt:
- wire the ISA shunt to 12v+ and canbus input.
- under shunt can in the web interface, select the canbus the shunt is connected to
- hit save parameters to flash.
- select "Init"
- Power cycle the vcu and shunt at same time (they should be on same 12v feed anyway).
- The shunt will initialize.
- Select ISAMode "normal"
- save to flash again
- reboot the VCU
Troubleshooting
Serial Connection
if the zombieverter fails in the middle of a software update and the Web User Interface is reporting "firmware: null" it's possible you'll need to re-flash the firmware, and bootloader via an STLink.
- Begin Zombieverter-ing.
