Main Page Old
Revision as of 23:37, 26 May 2020 by Mdrobnak (talk | contribs) (Links to EV Conversion Parts sections)
Getting Started
The open inverter project consists of three main aspects:
There are two variants available:
Kit for use with your own power section. Kit for use with existing power sections,
This is the kit provided to build your own power section, meaning sourcing and constructing your own IGBTs and other components.
You can find the build instructions for this kit here
This is the kit for use with existing power sections, meaning inverters sourced from OEM parts taken from existing cars, etc. and utilising the components within them.
For example drop in boards for Tesla drive units, Prius Inverters, and so on.
Once you have the inverter parts, you will need additional components for your EV conversion:
More detailed information on these items can be found on the EV Conversion Parts page.
FAQs
Open Inverter Hardware
Open Inverter Software
Open Inverter CAN std.
Glossary of Terms
Conversion Projects
OEM Parts
