Toyota Prius Gen3 Board
Revision as of 07:05, 10 July 2020 by Bobbycomelately (talk | contribs) (Updated pinout tables to add pin numbers)
Prius Gen3 Control Board v2
Prius Inverter
Control Board
Prius Gen3 Partial
Development History
Vendors
- ?? List of known vendors with support?
Support
Inverter Model Numbers
G9200-47141 Auris 2012, RHD
G9200-47190 Auris F1759-52010 04 ? Forum Thread openinverter.com
G9200-52010 Yaris F1759-52010 04 F1789-52010 154x143mm https://openinverter.org/forum/viewtopic.php?f=14&t=257&p=5828#p5828
Soldering The Breakout Board
Soldering the Main Board
And Conn8, again easy.
[add photo]
Powering up
Checking voltages
Check for ~3.3v here on C32
Finally the 26v
Firmware
Wifi Module Firmware
Main Firmware
For Windows
Atmega328p Firmware
First Run (PWM verify)
Navigate to the Web Interface
Stop the inverter
DC-DC Converter
12v Battery Connection
Motor Connection
IDC Connector
If you are not using the AMPSeal daughterboard, you can connect directly to the 34 pin IDC connector on the EVBMW board. Connections are as follows:
Pin Number Label Description
23 MG2_STATOR_T1 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V.
24 MG2_STATOR_T2 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V.
25 MAIN_CON 5V output to switch main HV contactor. Note that you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current.
26 PRECHG_RLY 5V output to switch the pre-charge relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current.
27 AC_CON 5V output to switch the main charger AC input relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current.
28 HV_CON ?
29 AC_PRECH 5V output to switch the charger AC input pre-charge relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current.
31 EVSE_PROX
32 CONTROL_PILOT
Ampseal Socket & Plug
22 MOTOR TEMP SENSOR A 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V.
23 MOTOR TEMP SENSOR B 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V.
24 MAIN HV CONTACTOR 5V output to switch main HV contactor. Note that you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current.
25 HV PRECHARGE RELAY 5V output to switch the pre-charge relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current.
26 CHARGER AC INPUT RELAY 5V output to switch the main charger AC input relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current.
27 CHARGER HV DC REQUEST
28 CHARGER AC PRECHARGE RELAY 5V output to switch the charger AC input pre-charge relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current.
30 EVSE PROXIMITY SIGNAL
31 EVSE CONTROL PILOT SIGNAL
34 NOT USED
35 NOT USED
Connecting Resolver
Damien's Prius Gen3 v2 Github
Bill of Materials (Github)
